Results 1 to 8 of 8
Thread: Changing Pro-Logic Panel after VSP to Dual Speed Pump
    Jan 2015
    Nevada
    16
    Changed out a Haward VSP to a Hayward dual speed pump. The Pump runs great and really moves the water. It was wired per the Pro-Logic book....http://edc.poolsupplyworld.com/wpdf/plps-manual.pdf page 14 Top of the page.
    I went into the "Config" pages to change to the new pump "2-Speed" but I must be missing something. When I push the "Filter" button once the pump comes on the "High" setting. If I push it a second time it just flashes and the pump doesn't got to the low setting. Kinda puzzed here. The old VSP when your turn on the pump if you wanted a different speed (1-4) you just pushed the + or - button. Regardless, I'm stumped right now. Anyone have some suggestions?
    Custom 12,500 IG Pebbletech pool with attached SPA (Built 1996), Cartridge Filter, Hayward EcoStar Var Speed Pump (junk after 4 yrs) REPLACED with Hayward TRISTAR Dual Speed SP32202EE, SWG Aqua T-Cell-15, Hayward Pro Logic PS-8 Pool Controller, Wireless Base Transmitter, Wireless Remote, Hayward Pool Heater HM250 (1996 manufacture date stamped), Zodiac MAX 8 Pool Cleaner
    mas985's Avatar
    Pleasanton, CA
    11,279
    Re: Changing Pro-Logic Panel after VSP to Dual Speed Pump
    Did you configure the low speed relay setting to low speed?
    Mark
    18'x36' 20k plaster, 1/2 HP 2sp pump, Aqualogic PS8 SWCG, 420 sq-ft Cartridge, Solar, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater
    Jan 2015
    Nevada
    16
    Mark, that does not sound familiar to me so probably no. When it's in "FILTER" its flashing telling me its going to low speed in x minutes once it times down I can hear a relay click but nada. Pump stops. If I push Filter again it comes on High no problem. Where do I configure the Low Speed relay?
    mas985's Avatar
    Pleasanton, CA
    11,279
    You set it in the configuration menu. Each Aux relay has a setting to what feature you want it to be. See page 33, under Aux Function. Of course you need to set the exact relay # to the proper function and in this case, Low-Speed.
    Mark
    Jan 2015
    Nevada
    16
    Ok..I'll check that. I think my AUX 1 is set to my pool light. Gotta go teach a class so will research that and execute in a few hours. I'll let you know if I have success....Thanks again for the QUICK responses!!
    Jan 2015
    Nevada
    16
    YOU ROCK Mark! That did it...I reconfigured AUX 2 (where I wired it) to FIlter Low Speed and then edited the "Group" as well. Still have not got the "filter" light to stop blinking but I'll tackle that tomorrow in the light. LOW speed is quiet! Checked my meter and in LOW it draws a little more but if it lasts longer than those VSPs being built its a WINNER! Pat
    mas985's Avatar
    Pleasanton, CA
    11,279
    The filter light is supposed to blink when on low speed. That's how you know it is on low. Glad you got it working.
    Mark
    Jan 2015
    Nevada
    16
    Makes sense. Thanks again!
