Results 1 to 8 of 8
Thread: High PH
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    High PH
    I have read How do I use Chlorine in my Spa (or pool) but I have a question... My pH is over 8. My HT is 410 gallons. Per the Pool Calculator, I am told to add 1 oz and 5 teaspoons of Muriatic acid to bring it to 7.0. I have been running it like the instructions stated for 30 minutes and it is still over 8. Do I continue adding acid unit it drops? How long should I wait between doses? Sorry for all the questions, but I really don't want to screw this up...
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: High PH
    Yes, your pH must have been well above 8.0. That is the highest the test reads, but it could be a lot higher. Add acid, pump running and retest in 15 or 20 minutes. Repeat until the pH comes in to range on the test.
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Re: High PH
    Thanks pooldv... It's a fresh fill and a CYA only add so I'm not sure what the deal is/was...
    8632 gallons
    ROLL TIDE!
    JoyfulNoise's Avatar
    May 2015
    11,854
    Re: High PH
    What's your TA? If your TA is high, your pH will go up like crazy in a hot, highly aerated tub.
    Matt
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Re: High PH
    TA was at 110...
    8632 gallons
    ROLL TIDE!
    May 2015
    11,854
    High PH
    That's way too high for a hot tub. The aeration and outgassing of CO2 at that TA level is very high and causes pH to increase rapidly.
    TFP recommends that hot tub owners reduce the TA to 50ppm and add 50ppm borates to the water. That drastically reduces the pH rise as the lower TA means less aqueous CO2 is generated and the borates act as a buffer against rising pH.
    Matt
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Re: High PH
    It's all under control now with pooldv's help!! pH is now at 7.2 and TA is a 55...
    8632 gallons
    ROLL TIDE!
    DFW, TX
    24,042
    Re: High PH
    Whoot!
