Thread: Ok, recommended or not good to close AT SLAM level?
    Jun 2016
    Marlboro, NJ
    87
    Just wondering if it is ok to close your pool at the SLAM level? Meaning actually putting the cover on over the pool while the chlorine level is at shock level based on corresponding CYA and the slam chart.
    Not sure if the chlorine at that level is ok long term over the NJ winter. Since my CYA is around 60 to 80 (will of course retest right before) my chlorine level is accordingly fairly high as well.
    Ok? Not ok? Or recommended?
    Trying my to avoid opening the pool green like last year. This site has helped me leverage liquid bleach at 5 to 7ppm all summer and no need to shock all summer long.
    Pool Type: In Ground, Liner. Shape: Free form/kidney
    Filter/Pump: Brand new (2016) DE Hayward 4820 / Brand new (2016) Pentair VST 2
    Heater: Yes (older)
    Location: NJ. No tree/leaves overhead. Limited shrubs near/over waterfall feature
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    4,558
    Re: Ok, recommended or not good to close AT SLAM level?
    It's perfectly fine to close at shock (SLAM) level for your CYA. Even more important than raising the FC to shock level is closing when the water temp is FIRMLY below 60 degrees. That's the single most important factor to opening to a non-green pool in the spring (and opening before it gets above 60...).
    Typically I will raise to shock level they day before I close, so by the time I drain some water and get closing complete, I'm likely a couple FC below SLAM level.
    Isolated Spa - 345 Gallons
    Jun 2016
    Marlboro, NJ
    87
    Close at less than 60 degrees eh? In NJ that might mean waiting until late October or even November. By then most of the pool closing people are done for the season!
    Jul 2014
    New York
    26
    I put the cover on my pool in mid to late September, but don't winterize it. I get all the chemistry perfect, bring the FC up to 1/2 of SLAM level (I have a vinyl liner and worry about fading if it doesn't go down quickly like summer). I also put in a Polyquat algeacide as a preventative measure. Per this forum, I wait until the temp is below 60 during the day. I usually bring the chlorine level back up and add some more Polyquat before I drain down the water to below all the openings. I then partially remove the cover to lower the water and blow out the lines.
    In the spring I reverse this usually in the middle of April and de-winterize the pool to start putting chlorine back into the water before I am ready to open it sometime in May.
    The one change I now need to figure out is I upgraded to SWG from an in-line chlorinator. I will need to either put bleach into the skimmer or powder shock into the skimmer to bring the chlorine back up before winterizing. There have been discussions on this and although it is not recommended, plenty of people do it with no proof of impact.
    21' x 28" Grecian Vinyl Pool (@17k gallons) with Pentair SuperfloVS VS, Hayward sand filter with Zeosand, and Hayward gas heater. Pentair EasyTouch 4PSC-IC40 (Pentair IC40 SWG), and Screen Logic interface. 2 skimmers with main drain on the intake side and two primary returns with two low flow bubbler returns at the stairs. Aquabot pool cleaner. TF-100 Test kit.
