Thread: Air Pillow Moved
    Sep 2016
    Northern Illinois
    Air Pillow Moved
    I wasn't very smart and I only tied ropes to 2 opposite corners and now my pillow moved to one side. Should I take the cover off and move it to the middle and tie it correctly or should I not worry about it?
    domct203's Avatar
    Jun 2015
    Re: Air Pillow Moved
    As long as the pillow is correctly inflated it should be fine I imagine.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    rajung's Avatar
    Mar 2015
    Not to sound sarcastic, but with my luck on any one of those blue colored pillows, after trying them many times I would go out there and stick a knife in it.Might be just me, but before I decided to go cover-less I found that usually they would deflate and sink anyway, and then freeze at the bottom.Or cause more water on one side of pool cover from not being centered.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
