Thread: Pac Fab ST-35 50
    Sep 2016
    Downingtown, pa
    2
    Pac Fab ST-35 50
    I picked up an ST-35 or 50, not sure if their is a difference?
    Anyway, when I started it up, their was a leak, a cracked ABS (Black ) plastic line on the line that states check valve.
    The crack extends through the threads and I wanted to try and repair the crack since it is, I think, on the backwash line?
    I would appreciate any suggestions on how to repair this crack and the material to use?
    I was considering using my Dremel tool and cutting a small wedge along the crack in the top of the pipe and filling it with
    some sort of sealant?
    Please advise
    Thanks
    John
    30,478
    Re: Pac Fab ST-35 50
    Welcome to the forum.
    If it's on the backwash pipe, that seems doable but far simpler would seem to be to replace the pipe. Do you have a pic so we can better understand?
    Sep 2016
    Downingtown, pa
    2
    Thanks for your input, and I would agree, except the back wash line is attached to the main body of the manifold and not replaceable!
