Slamming with old copper pipes
Sep 27, 2016
55
N/A
I recently talked to a pool contractor and he said copper used to be the material of choice for skimmer and return pipes. But over time, they didn't last up under the chlorine and are now being replaced. We have copper pipes that are well past the normal lifespan (30 years) and are concerned about keeping them corrosion/leak-free.
What risks would I be taking when slamming a pool with very old copper pipes?
For copper, your biggest enemy is pH, not chlorine. Metal corrosion is entirely dominated by pH. Copper corrosion is easily initiated at low pH (<7.0) because the cupric ion (Cu2+) is stable below a pH of 7.0.
So you need to limit your pipes exposure to low pH by not using acidic sources of chlorine (trichlor or dichlor) and by always diluting acid additions in the deep end of the pool. If proper water chemistry is maintained, copper pipes can last for decades.
Municipal water is chlorinated and copper pipes last many decades in homes carrying chlorinated water. Water with FC of 1 ppm and 0 CYA is harsher than water with CYA and FC at shock level. What municipal water supplies do is make sure the pH is never below 7.2 to avoid corrosion of pipes.
