Results 1 to 8 of 8
Thread: Infamous 170 code
    Sep 2016
    Brandon MS
    4
    Infamous 170 code
    Getting 170 code. The sensor (3 prong) plugs into the small board, then that plugs into the main board. looking at the display, no lights are on and the display just says 170. When I unplug the sensor and small board, the lights come on the display.
    I just replaced the sensor last year. Lesson learned not to be a tight wad and buy a "like new" off eBay. Wanted to run in by the pros before I bought another one. -- new this time-
    Jun 2011
    Long Beach, CA
    2,732
    Re: Infamous 170 code
    Welcome to TFP!
    Make sure you get the newest revision, it has a small control box in-line and it will have an option to run program A or B.
    Sep 2016
    Brandon MS
    4
    Will do.. I appreciate it.
    Im guessing my issue will be the sensor?
    Jun 2011
    Long Beach, CA
    2,732
    It might be the transformer so you should troubleshoot the system before you replace anything. Search the net for Jandy Aquapure Workbook and you should find a guide on how to troubleshoot the system. Some of the links here at TFP are old and don't work when searching for it, but I was able to find it on the net not too long ago.
    Mar 2015
    New Orleans, LA
    81
    99% of the time SENSOR
    Sep 2016
    Brandon MS
    4
    I been researching on how to troubleshoot, but they are telling me to check 2 diff boards... When I pull the cover off, I just have one board. Any tips on making sure it's the sensor before I take the plunge and buy a new one?
    Jun 2011
    Long Beach, CA
    2,732
    Try this guide, https://premium.zodiacpoolsystems.co...ce3d54eb51.pdf. It is the latest guide and should have everything listed to troubleshoot the SWG.
    Inspect the cell for any wear on the plates and loose pins. The center plate usually is the first to degrade.
    Use Scotchbrite on the sensor to clean it.
    Sep 2016
    Brandon MS
    4
    Man your a lifesaver!!!! I ran the tests and the voltage test for the transformer and regulator checked out. Looks like I'll be buying a new sensor tonight.
    I appreciate the help!!!
