Thread: Pressure Test
    Jul 2016
    Plano/Texas
    8
    Pressure Test
    Hi all,
    We had our new pool's plumbing installed 2 weeks ago and they put 23lbs of pressure in the line to pressure test. There has been a ton of activity back there during those 2 weeks (tile, coping, stonework, deck forming, rebar, sand) and I noticed that the gauge has dropped to 20lbs. There has been about an overall 10-15 degree drop in temperature during that time. The decking is getting poured in 2 days and want to be sure that there aren't any leaks before hand.
    Should I be concerned with a 3lb drop in pressure over 2 weeks or is that normal?
    Mar 2016
    Chino Hills, CA
    185
    Re: Pressure Test
    When my pool was being built early this year we had the same issue. It was due to the weather change. If there was a leak there would be zero pressure after a day or so. Probably nothing to worry about.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,926
    Re: Pressure Test
    If you only lost 3 lbs in 2 weeks, you're good.
    Divin Dave,
    Jul 2016
    Plano/Texas
    8
    Re: Pressure Test
    Thanks for the info!
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    835
    Re: Pressure Test
    Quote Originally Posted by PlanoDave View Post
    I wouldn't be concerned with a 3 lb change. Since water is incompressible and the piping & equipment is made from fairly rigid materials, it wouldn't take much of a leak to drop that pressure to zero over the span of 2 weeks. Only a small amount would have to leak out to relieve the pressure. It's not like your car tire that can have a small leak and still hold pressure.
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
