Thread: pool pump timer
    Sep 2016
    ontario, Canada
    5
    pool pump timer
    Looking for a recommendation for a timer for pool pump with 230v .
    Jun 2014
    15,895
    Re: pool pump timer
    Intermatic has a long line of timers for various applications and are quite popular with pools owners. Here are some links you might wish to review:
    Intermatic T104M (220V): How to Replace an Intermatic T104M 240V (208 277 V) Pool Timer - YouTube
    T100 Series: http://www.intermatic.com/~/media/in...eries-2pgs.pdf
    Inyopools.com Intermatic Timer Descriptions: Intermatic Timers - Pool Timers - INYOPools.com
    Sep 2014
    Grants Pass, OR
    33
    Re: pool pump timer
    You might also consider a Intermatic Freeze Control which will turn your pool motor on at 32 degrees and off at 35 degrees.....
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    371
    Re: pool pump timer
    i second the Intermatic brand. that is what i have on my pool. it has worked flawlessly for the last year. i had it set to turn on at different times of the day. will probably go with the freeze protector this next year because i will be leaving my pool up from now on.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Re: pool pump timer
    Hi. It would be great if you edit your signature and include a list of your pool details (size, shape), equipment, accessories, ... like you see others do. This helps people give better replies for your specific case. For example, do you have a saltwater chlorine generator (SWG)? If so, you would want that to come on with your pump (maybe sometimes, maybe always). Is your pump a single speed, dual-speed or variable speed? Most variable speed pumps can be connected directly to power and have their own programming for speed/on/off in the pump itself. If dual-speed, you may want a timer that can pick which speed to turn on, or you can have a hard wired external switch on the pump. Some SWG have timer functions and pump control relays built in (i.e. AutoPilot).
    Intermatic does have a wide line as stated, from manual to digital, for single and dual speed,...
    [edit] Sorry - just saw the original post was a while back. Regardless, please edit your signature.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Dec 2015
    Orlando, FL
    42
    Re: pool pump timer
    I happen to have an Intermatic T104M that is nearly new. I purchased it and then shortly thereafter replaced it with an automatic system. PM me if you'd like it for a good price.
