Thread: Help with calculating pool water volume
    Sep 2015
    owasso, ok
    41
    Hi there, could not really find a good place to post this so here goes...if it needs to be moved no problem there. Im getting conflicting answers on water volume. We have lived in the house a year and its a custom pool with no standard shape. I have attached a pic of what the builder gave to the previous owners....nowhere does it show on any of the pool paperwork how much water is in this pool. In order to make adjustments, which I haven't done very well so far, I need this. I was told 24000 gallons but using the calculators I have come across its hsowing a lot more. The particulars are in the upper left corner......Can I get some thoughts here on how much volume?
    Hayward Aqua Rite Salt pool
    Dolphin cleaner/PoolCleaner
    Pentair Triton II filter
    Heater
    approx. 24000 gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Help with calculating pool water volume
    Without detailed measurements it will be hard to say, but I suspect the 24,000 gallon guess is in the right ballpark, which may mean 25,000 or even 27,000 gallons,
    Without knowing the bottom profile, particularly in the deep end this is all a guess though, at the top end of the range it might even be 32,000 or so
    JoyfulNoise's Avatar
    May 2015
    13,405
    If you look up "chemical method pool volume" in the search bar, user onBalance describes a chemical method for getting pretty close to your exact water volume. It does require quite a bit of TA test reagents to do the test but it does work.
    Matt
    Jun 2016
    Panama City
    100
    I would break each section of pool into blocks. Then use length x width x height in inches divided by 231. That's how I find gallon volume in aquariums. Let's say you have a 6' x 2' x 2' aquarium...72x24x24=41472. Divide by 231= 180 gallons approximately! So if you have the deep end which is 10' by 20' and is 7' deep it is 120x240x84231. That would be 10,470 gallons or so.
    6500 gallon SummerWaves AGP. Taylor k-2006, Jacuzzi sand filter and two speed pump. City water. Third year in use!
    Sep 2015
    owasso, ok
    41
    Quote Originally Posted by JEC11718 View Post
    Sent from my XT1254 using Tapatalk
    Great idea I'll try that!
    Heater
