Thread: Pool Heater Spraying water
    Apr 2016
    Tampa, FL
    3
    I just went outside and noticed that my Summit Sum 5 heater is gushing water upwards from the bottom inlet pipe that appears to have some sort of small valve/opening on it. I've only owned this house and pool for about a year, so I'm not terribly familiar with the inner workings of the heater.
    Any idea what this is or why this is happening?
    Here are a couple pics I grabbed :
    Shared album - Robert Krueger - Google Photos
    domct203's Avatar
    Jun 2015
    CT
    3,685
    Re: Pool Heater Spraying water
    Welcome to the forum.
    That looks like the remains of a (broken) barbed hose fitting, possibly for some kind of water flow monitor.
    Is there a small diameter hose in the area that has one end disconnected?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2016
    Tampa, FL
    3
    You called it, Dom! Took the top off and found the small hose lying there with a broken piece of barbed plastic inside. Makes sense that the heater was reporting no Flow while this was happening.
    This looks like a much easier fix than I initially anticipated.
    Thanks!
    domct203's Avatar
    Jun 2015
    CT
    3,685
    Glad to help!
    Be sure to use teflon tape on the threads of the replacement.
    Dom - TFP Guide
    Apr 2016
    Tampa, FL
    3
    Quote Originally Posted by domct203 View Post
    Glad to help!
    I sure did. I used some pipe dope in addition to the tape as well. I also went with a brass fitting so this doesn't happen again.
    Thanks again for the help!
