Thread: Building 2nd Pool - Waterfall question
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    55
    Question Building 2nd Pool - Waterfall question
    We've moved and are building our second pool. We're building the exact same pool as the first as far as size, shape etc. However, this pool will have an actual waterfall using the huge rocks in our backyard. We wanted to seal the rocks (top and bottom) but the pool guy said that the mason suggested we wait until the waterfall is constructed and then seal it. "Sealing it before may compromise the mortar when he's building it."
    THOUGHTS?
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    Mod Squad pooldv's Avatar
    DFW, TX
    20,344
    Re: Building 2nd Pool - Waterfall question
    Sounds logical to me.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,809
    Mee too, I bet the mortar doesn't stick well to the sealed surface.
    Have you read much about ph rise and water features?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Feb 2014
    Georgetown, Texas
    55
    I have not but I will research that. Our last pool hand a very simple waterfall. Thank you both!
    Judith and Brian D
    JoyfulNoise's Avatar
    May 2015
    8,743
    Please make sure the PB uses a proper waterfall pump for the application. Too often PB's try to just slap on another pool pump to the build and pool pumps are high head (pressure) pumps while waterfall pumps are designed for open-pipe (low head), high flow rate applications. Take it from my experience where our pool's waterfall was installed with a GIANT 3HP Pentair WhisperFlo pump...it is way too powerful and I had to add extra shutoff valves to it to create enough back pressure to keep the pump from cavitating. Also, don't be talked into just splitting off some flow from the main pool pump to make the waterfall happen. If they do that, more often then not they have to rob so much water flow from the pool pump that very little water goes through the returns. The best design is a separate set of wall intakes to a properly sized waterfall pump with all the return water sent to the waterfall. They can even add an additional wall return in case you want to split the flow from the waterfall to a wall return to get the exact amount of splashiness and sound you like.
    As for the rocks being sealed, I would agree with the recommendation to wait BUT, honestly, I have had my waterfall for years now with a salt pool and the stones are unsealed and there is no issue.
    Matt
