Results 1 to 8 of 8
Thread: Two questions
    Mamamartini's Avatar
    Sep 2016
    Wilmington, OH
    34
    Two questions
    Still slamming, but the deep end is still not clear. It's clearer than when I started, but it's nowhere close to being a safe area to swim in. I bought a Dolphin this weekend, and the stuff that came out of the deep end was astonishing.
    Here's my other question. I realized midway through slamming that the shallow end has different Chlorine levels than the deep end. Now I'm testing both ends each time, and treating each end. Should I just test the shallow end?
    I'm kind of over all this.
    Viking Spas 300 gallon ETS-5 hot tub, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Re: Two questions
    How different is it? Are you running the pump 24x7? Brushing daily? Scooping and vacuuming? That should keep it mixed. The more you brush and get debris out of the pool the faster the SLAM will go.
    Sep 2016
    Wilmington, OH
    34
    Re: Two questions
    Quote Originally Posted by pooldv View Post
    Usually it's off by 2. Normally the shallow end is two less than the deep end, but sometimes the deep end has less FC. I run the pump all the time. The dolphin vacuums (after I attempted it once). I was brushing at least once a day until I felt defeated.
    I guess the robot stirred up some stuff at the bottom and possibly caused a delay?
    DFW, TX
    24,748
    Re: Two questions
    Kinda weird. Is the return flow good? Are you backwashing the filter when pressure rises 20-25% above clean pressure?
    Re: Two questions
    Like what pooldv said it seems like your flow must be off with such a difference. If it's working well it should be circulating the water pretty well and keep the pH pretty similar no matter what end you're on.
    Sep 2016
    Wilmington, OH
    34
    Re: Two questions
    So, this morning I decided to get over myself and go brush the sides, and I could SEE THE MAIN DRAIN! For the first time since we moved in, I can see the bottom of the deep end : ) I still have work to do, but this is exciting!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,191
    Re: Two questions
    Good job! Glad to hear it.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Sep 2016
    Wilmington, OH
    34
    Re: Two questions
    Actually no, I wasn't. Clean for my filter is 13 PSI, but I was letting it get to 18 or 19 before backwashing. I corrected that as of today, and will be doing this going forward. Thank you!
