Thread: Fresh Fill after new Vinyl Liner installed
    Jul 2014
    New York
    34
    So my water looks clear with slight greenish tint and some brown sediment on the bottom that I brushed up last night.
    Should i bring the CH up to my target 200 first, then treat the assumed metals in my water (sent my wife to get the water tested at pool store today)?
    FC - 6.5
    CC - 1.0 (never had above .5 before, do I need to do anything to get this down)
    PH - 7.3
    CH - 25
    TA - 75
    CYA - Added 4lbs, haven't tested yet
    21' x 28" Grecian Vinyl Pool with fiberglass steps (@17k gallons) with Pentair SuperfloVS, Hayward sand filter with Zeosand, and Hayward gas heater. Pentair EasyTouch 4PSC-IC40 (Pentair IC40 SWG), and Screen Logic interface. 2 skimmers with main drain on the intake side and two primary returns with two low flow bubbler returns at the stairs. Aquabot pool cleaner. TF-100 Test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,742
    Re: Fresh Fill after new Vinyl Liner installed
    We are not fans of pool store testing. It is often not accurate. I use the TF-100 from TFTestkits.net. Pool School - Test Kits Compared
    There is no need to raise CH in a vinyl pool. More here, Pool School - Recommended Levels
    Jul 2014
    New York
    34
    So why does the vinyl liner manufacturer recommend CH range of 175-250?
    DFW, TX
    24,742
    I do not know. But, raising CH to 175 is fine, there is no reason not to other than cost and effort.
