Results 1 to 10 of 10
Thread: Sump pump for closed pool
    Sep 2015
    Columbus IN
    52
    I am going to use a sump pump to mix chemicals this winter as needed. What I was wondering what do people use on this forum that use a sump pump for that purpose use to protect the vinyl liner when the pump is in the pool. My pump is all metal on the bottom so I am concerned about damage to the liner.
    15000 gal, IN, Hayward Super Pump VS, Hayward Heat Pro Titanium heat pump model number HP2110T, vinyl, Dolphin Apollo.
    Hayward sand filter model number S210T, TF-100 test kit with speed stir. It was built in 2012.
    ka8yiu's Avatar
    Aug 2016
    SW FL
    117
    Re: Sump pump for closed pool
    I am not using a pump like you are planning, but I did recently acquire one to help with overflow issues during torrential rains like I've had recently.
    So, to protect my fiberglass, I drilled 1.5 inch holes around the bottom of a 5-gallon bucket, and I'll place the pump inside of it so it is not in direct contact with the fiberglass and gel coating.
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    Use one of those plastic milk crates that holds 4 gallon of milk that you see laying around. That's what I use when I sit my pump on my cover in the winter. You can put bottles or milk containers in it, to help it stay standing up too.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Sep 2015
    Columbus IN
    52
    That is a good idea. I already have a milk crate.
    rajung's Avatar
    Mar 2015
    Iowa
    164
    Not sure I would use a sump pump.
    I used a brand new one, purchased just for this1/2 hp a couple years ago to aerate my pool, let it run 48 hours which brought ph up from 7 to 7.8 in short order.
    The next day I had a heavy black sticky film at the water line level half way around pool which was a pain in the ### to remove, and may have contributed to some water level liner fade, liner 2 years old.
    The pumps are oil filled, lesson learned for me.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Sep 2015
    Columbus IN
    52
    Ok thanks. How does everyone mix bleach into the water in winter when pool is closed??
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    I was under the impression that if you bring you water up to slam level before you close for the winter, you do not need to add any bleach for the winter. I did this last year and opened up to a very clear pool. Some people, including myself do add Polyquat 60 before closing as well.
    Mark
    Sep 2015
    Columbus IN
    52
    If that is the case that will work for me. I am planing not to close until water temperature stays below 60.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    My water temp is down to 69 now, and cooler weather is here but they are calling for temps in mid 80s next week. I am switching over to bleach today and resting the SWG for the rest of the year.
    Mark
    rajung's Avatar
    Mar 2015
    Iowa
    164
    Here in Iowa,all I have done is wait till the temp of water stays at 60 or below, once I leave the heater off for the season.Usually mid to end of October .Raise FC level to SLAM level in accordance to my CYA level.I then add 60 algeacide, 16 oz for my pool.Let it circulate for a day,lower water with the pump set on waste to below skimmer, before pumps starts to suck air.
    Remove more water to 6 inches below return fitting with another pump( not a sump pump), I use a small gas powered transfer pump with a hose into pool.
    Disconnect everything inc. the sand filter and store in garage.I have had an issue where I drained the filter and left drain open and covered and the next spring had a leak in the seam of tank.Maybe overkill now, but sand is easily removed.Disconnect all lines to pool, vacuum water out of heater and cover.Plug return and plug front face of skimmer with plate, and this year put a 16 oz. bottle with 8 oz. RV antifreeze dropped into skimmer.Last year even with skimmer face blocked off" they aren't water proof" skimmer had a chance to get a block of ice in it, even with bottom connector open to the ground.Not going to chance it again.No trees, so I don't cover the pool anymore, too much work getting the snow build up off every time it snows.Next season usually all the levels of pool water are at near zero for me. But when you open early enough, before water gets above 60 deg. again and balance the chemicals, all should be fine.I have never had Algae issues.
