Thread: How much water loss is acceptable?
    Sep 2016
    Lancaster, CA
    87
    Hey,
    In one month of owning a pool, I have to add water it seems every week or two because it's dropping an inch or more every week or two. I didn't track it closely though.
    So I went on a 5 day trip, and came back and it lost at least an inch, probably closer to two.
    I haven't been keeping a cover on it, it's still will into the 90s still here, can evaporation do that much loss? Do I have a leak somewhere? There is no visible leaking with any of the pool equipment or external piping.
    ~14k Gallon IG Plaster (old)
    Hayward DE 4280 Filter
    Pentair Superflo SS Pump
    Built 1993
    Old Broken Heater that needs to get replaced!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: How much water loss is acceptable?
    1/8"-1/4" is typical evaporation.
    Sep 2016
    Lancaster, CA
    87
    Quote Originally Posted by pooldv View Post
    Per day?
    I also forgot to mention my plaster is really old and needs to be replaced. Does that play into loss?
    Built 1993
    DFW, TX
    24,042
    Yes, per day. Yes, old plaster can start to get a little leaky.
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    I lose 1/2 inch minimum a day during the summer
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Sep 2016
    Lancaster, CA
    87
    Quote Originally Posted by Mark R View Post
    Okay, that seems to be closer to what I'm losing, Just wanted to make sure something wasn't wrong.
    Built 1993
