Thread: maytronics dolphin power supply repair
    Oct 2007
    Parkland, FL
    732
    Anyone attempt to repair the power supply? Mine popped and died tonight conveniently 3 days after the two year warranty was up.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    15,001
    Re: maytronics dolphin power supply repair
    Man that stinks. Maybe they will work with you since its so close.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree call them, giving specific advice is hard as they made more than one type. The older ones I have been into were very simple, a big transformer and a bridge rectifier plus maybe a fuse and a power switch.
    Dec 2014
    Riverside California
    474
    Quote Originally Posted by Isaac-1 View Post
    The newer ones are lightweight, which tells me that probably a switch mode power supply is used. Also, there must be some sort of microcontroller to handle remote communications and send commands to the robot.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
