Thread: Help me understand my valves
    Feb 2016
    Marysville
    8
    I have these valves on all my lines. This one is for the return line. The side labeled #1 is water line from the pump. #3 is the line to the Pool water return (the eyeball).
    What are the different Positions used for?
    28' Round Ester Williams. 4'-8' deep buried AG Vinyl liner.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    6,949
    Re: Help me understand my valves
    Runt,
    Not sure what the valve is for, but putting the "off" arrow toward either the 3 or the 1 will have the same effect of shutting off the line.
    My guess is that you don't want water coming out of your pool and then out of the pump when the lid is off, so to prevent that from happening, you'd turn the valve to either 1 or 3.
    A picture from a little further away would give us a better idea of what the valves are for.
    Feb 2016
    Marysville
    8
    Quote Originally Posted by Jimrahbe View Post
    Runt,
    This helpful?
    Pool Valves - Album on Imgur
    so 1 & 3 are off. 2 and 4 are open? Any difference bewteen 2 and 4?
    Jul 2014
    Bedford, TX
    6,949
    runt,
    I can see no difference between position 2 and 4, both open the pipe. I say this based upon how a regular Jandy valve works. I would expect this valve to work the same way.
    Feb 2016
    Marysville
    8
    Thank you!
