Results 1 to 10 of 10
Thread: Jandy Aquapure 1400 Salt Chlorinator
    Sep 2016
    Tyler, TX
    2
    Hi All - New Member - First Time Posting...
    I have a 40,000 gallon pool with all Jandy equipment installed in late 2013. Salt generator is a Aquapure 1400 with a Pure Link control center
    I have had several issues with it in the past - mainly NO FLOW alerts and low chlorine production.
    The cell is now 3 yrs old and has thrown a 170 code and the issue is with the chlorinator flow sensor.
    Im looking for advice, and I think I have 3 options -
    1. Get away from Jandy and get another chlorination system - kinda hate to do this since everything I have is Jandy, but not at all pleased with the last 3yr performance.
    2. Get a new Jandy 1400 cell with the new (supposedly better) flow meter. - this is cheapest and easiest but is the flow sensor issue really fixed.
    3. Upgrade to a new Jandy TruClear - but are they any good and does this mean I need to replace the Pure Link control center also?
    Any advice is appreciated including any options I haven't considered...Thanks in advance.
    -Jeremy
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,881
    Re: Jandy Aquapure 1400 Salt Chlorinator
    Jeremy,
    I would suggest seeing if Jandy has a much larger cell. The 1400 is advertised for pools "up to" 40K. This means they will just barely work with a 40K pool if run at 100% for 24/7.
    I believe that having all the same equipment brands is the best thing to do if possible.
    Sorry, but I'm not up on Jandy equipment. Let's see if we can get some Jandy experts to chime in..
    Sep 2016
    Tyler, TX
    2
    Thanks Jim - If that's the case I wonder if I could install two cells with one control center? I'm not sure they make a larger cell.
    Jun 2016
    Martinez, CA
    214
    I have the 1400 system which I recently replaced from an earlier model that was not very reliable. Time will tell if reliability is any better but there appears to have been many design changes compared to my old one. I'm crossing my fingers this one will be problem free.
    BTW- our 19k pool runs 8hrs a day to maintain chlorine level running at 100% so it would have a hard time keeping up with your system. Theymdont make a bigger unit but a few models from other mfgs offer twice the output. I'd suggest looking at one of the other mfgs that make much larger systems so you can save electicity on runtime. Although integration into the controller is nice, its not a deal breaker.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jun 2011
    Long Beach, CA
    2,840
    From the reports received over the last year, the latest sensor has fixed the flow issues. I've seen very few, if any, flow issues with the latest sensor design.
    May 2015
    Fullerton, CA
    642
    When was the new design introduced? My jandy 1400 was installed last December, but i just fired it up 3 days ago.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Jun 2011
    Long Beach, CA
    2,840
    It has been over a year but I'm not sure exactly when it was released to the public. I found out about the sensor about a month after I switched over to Hayward and that was about 15 months ago. Do you have the old style or new style of sensor?
    May 2015
    Fullerton, CA
    642
    I believe the new style, it has a little control box in-line.
    Mar 2015
    New Orleans, LA
    81
    There is a way to install 2 cells. Call Jandy tec support. Also I take care of a big pool and what we do during the hottest part of summer id add additional chlorine because the cell just barely keeps up.
    Jun 2016
    Martinez, CA
    214
    Quote Originally Posted by ConradM View Post
    Didnt know that. Lets us know what you find out. I may want to do this as well.
