Thread: Tile grout
    ka8yiu's Avatar
    Aug 2016
    SW FL
    103
    Tile grout
    I have several small holes and nicks in the tile grout. Is there any particular product to use for spot repairs, or is some form of grout repair from home improvement stores sufficient?
    K
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    JoyfulNoise's Avatar
    May 2015
    11,837
    Re: Tile grout
    Is the tile grout white?
    If you look up "Pool Patch Tile Grout" online, you will get lots of hits for white and grey tile grout. For small holes like that, be sure the surrounding tile is clean and the hole is free of debris and dry (lower the water line below the tile line), then apply the grout to it. You can even tool the grout line a 1/4" above and below the hole to try to blend it in better.
    Matt
    ka8yiu's Avatar
    Aug 2016
    SW FL
    103
    Re: Tile grout
    It's off-white.
    I once had similar small holes in floor tile grout. I used a small tube of grout with an applicator, like caulk, to fill the holes. I just wasn't sure if that was sufficient or there was a special product someone knew about.
    TF-100 Testing Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,038
    Re: Tile grout
    You can use pool putty or ABC compound and just moosh it into the holes underwater. They both cure underwater. No draining, no muss, no fuss. Color might not match exactly but much easier.
