Results 1 to 11 of 11
Thread: New Pump Necessary?
    Sep 2016
    Coppell, TX
    5
    New Pump Necessary?
    Our pump US Motors Model No. K63CXESE-4792 has sprung a small leak along the rusty clamp that holds it together. I'm trying to determine if we can just replace the clamp or need to get a whole new pump. Of course, the pool store said it's almost as expensive to replace the clamp as the whole pump, so why not just replace the whole pump. Seems nonsensical to me, so I'm looking to this forum to fact check that for me and perhaps tell me where to find it. I've not had much luck on the Internet.
    If I do in fact, need a whole new pump, which brand, size is best for a 14K gallon salt pool with spa, two skimmers, no deep end....waterfall and vacuum on separate pump?
    Thanks, all
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    2,119
    Re: New Pump Necessary?
    James,
    Welcome to TFP...
    I doubt it is just the clamp, more likely a seal between the motor and the pump.
    If you can post a picture of the pump and motor assembly, I'll bet you'll get a better response.
    TF100 with SpeedStir and SampleSizer, ColorQ Pro 7, Dolphin Premier Robot Cleaner, added Screen Logic 2.
    Isaac-1's Avatar
    SW Louisiana
    6,704
    I agree a photo would help, it sounds like this may be a store brand pump, not one from one of the major pump makers
    Sep 2016
    Coppell, TX
    5
    Attached are four photos. The first shows the actual leak location in the lower left. The others show the pump. It's difficult to get a good shot of it. The last is the label off the pump. When I googled it, the maker appears to be Emerson?
    IMG_20160927_154035600.jpgIMG_20160927_154054445.jpgIMG_20160927_154108013.jpgIMG_20160927_120942853.jpg
    Thanks for your assistance!
    mas985's Avatar
    Pleasanton, CA
    10,304
    The leak looks like it is from the pipe connection to the pump. It also looks like someone tried to repair it once? I think you could dry off the area and then see where it comes out first.
    Mark
    18'x36' 20k plaster, 1/2 HP 2sp pump, Aqualogic PS8 SWCG, 420 sq-ft Cartridge, Solar, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater
    Sep 2016
    Coppell, TX
    5
    If you look closely at the very first photo you can see the rust point on the metal band on the lower left and can actually see the water spraying out in the photo. I have a video, but don't see how to post it.
    Yes, there is also a tiny drip from the pipe connection that has been repaired once...needs it again. Was waiting to see if the metal band meant a whole new pump.
    14K gallon salt pool with spa. Two skimmers. Waterfall and vacuum on separate pump.
    mas985's Avatar
    Pleasanton, CA
    10,304
    Ok, I missed that. But I don't think that is the band unless the band does not close properly. However, that could be the gasket/o-ring that is no longer sealing. That can be replaced fairly easily. Have you taken it apart to inspect?
    Mark
    Sep 2016
    Coppell, TX
    5
    I haven't. Clearly the band is rusted ...almost through...and would need to be replaced. Searching to find if that is even a part that I can purchase before taking next steps.
    Isaac-1's Avatar
    SW Louisiana
    6,704
    You might be better off replacing it with a more economic 2 speed or variable speed pump
    mas985's Avatar
    Pleasanton, CA
    10,304
    I believe that is a Challenger pump (motor is not relevant) and you can find the parts here:
    PAC-FAB / TRITON CHALLENGER pool pump parts, Discount parts for PAC-FAB CHALLENGER pumps
    Or most any pool store.
    Mark
    Sep 2016
    Coppell, TX
    5
    Thanks. Will take a look at the link and see if I have more questions.
