Thread: Bucket of Saline 7 from the pool company. Do I need? Ingredients as follows:
    Jun 2016
    Goshen CT
    19
    Product Name: Saline 7
    Synonyms: Potassium Peroxymonosulfate; Potassium Hydrogen Sulfate;
    Potassium Monopersulfate Sulfate; Pentapotassium
    bis(peroxymonosulfate)bis(sulfate); Potassium Peroxysulfate
    Chemical Name: Potassium Monopersulfate
    Chemical Formula: HKO5S 0.5HKO4S 0.5K2O4S
    CAS Number: 70693-62-8
    Product Use: Non-Chlorine Water Shock
    What would I use this for? Thanks!
    NW Connecticut Outdoor 1980s Vinyle SWG 24,000 gal. rectangle 40' x 20' x 4'
    Hayward AquaRite w/ T Cell 15 Pentair Superflo VS
    Pool Testing: Taylor K-2006 and Taylor Saline testing kit
    JoyfulNoise's Avatar
    May 2015
    8,706
    Re: Bucket of Saline 7 from the pool company. Do I need? Ingredients as follows:
    Return it if it is unopened. MPS has very little use in a residential outdoor pool as it is not an effective sanitizer and it doesn't work as well in colder pool waters. It is mainly used in spas and hot tubs to provide a secondary oxidizer for bather waste, especially in tubs that might use bromine or one that uses a silver mineral ion disinfection system.
    And, if you use it in your pool, it will interfere with the FAS-DPD test and show up as excess FC.
    Matt
