Results 1 to 7 of 7
Thread: Pool company says they need to add Winterset and Anti-freeze for pool closing
    Jun 2016
    Goshen CT
    19
    Hiya TFP people-
    Well since joining the community I've done a great job of maintaining my pool chemistry. My pool is scheduled to close this pm. I have still retained my company to help me with this as I can't handle the cover myself.
    Free Chlorine: 3.5
    Combined Chlorine - none/trace
    PH: 7.6
    TA: 80
    Calcium Hardness: 180
    CYA: 96
    Salinity: 2800ppm
    The pool company says it wants to put in Winterset - a cold weather algaecide and Anti-freeze. I live in a place that gets pretty cold during the winters (Hills of Western Connectictut). Are these products necessary? I'm sure the antifreeze is. Asking more about the Winterset. It's from Phoenix Pool products and its not on their site. I just want to know as much about the proper procedure as possible.
    How are my levels for closing of the other chemicals?
    Thank you.
    NW Connecticut Outdoor 1980s Vinyle SWG 24,000 gal. rectangle 40' x 20' x 4'
    Hayward AquaRite w/ T Cell 15 Pentair Superflo VS
    Pool Testing: Taylor K-2006 and Taylor Saline testing kit
    domct203's Avatar
    Jun 2015
    CT
    3,504
    Re: Pool company says they need to add Winterset and Anti-freeze for pool closing
    Quote Originally Posted by zagoren View Post
    Hiya TFP people-
    Free Chlorine: 3.5
    PH: 7.6
    TA: 80
    CYA: 96
    Salinity: 2800ppm
    Thank you.
    I close my AGP with just chlorine. Sorry no help on the antifreeze as I just blow out the lines after draining below the return.
    If you CYA is 100ppm (how did you get 96ppm with the K2006?), your minimum FC is 5ppm, with your daily target at 8ppm (for SWG pool). You really should get that FC up right away.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Goshen CT
    19
    Quote Originally Posted by domct203 View Post
    I meant cya of 90. Mistake thanks. Will turn on superchlorinate
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Anti-freeze is OPTIONAL to put into the lines after blowing out all the water. It's not essential but is good insurance. As long as the lines are blown out well, antifreeze is just insurance in case the lines leak water into them over the winter.
    Putting half a gallon of antifreeze in each plugged skimmer, with the remainder left inside the bottle, also in the skimmer is RECOMMENDED.
    Algaecides are even more optional than antifreeze. If you close with the pool water less than 60 degrees, bring the FC up to shock level for your CYA and cover with a winter cover, you should open clean in the spring with or without algaecide. Can also be thought of as insurance rather than required. The only algaecide I would ever recommend is a polyquat-60 based algaecide. NEVER algaecides containing any copper of any kind. Check the label. If you don't know what's in it, don't put it in your pool.
    Isolated Spa - 345 Gallons
    Jun 2016
    Goshen CT
    19
    Thanks!
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,142
    Jul 2014
    Connecticut
    1,142
    It's a copper based algaecide, I'm not a fan.
    But Phoenix is a great family biz & a pleasure to work with with great quality product & they are in my hometown..
