Thread: Is vacuuming required?
    Aug 2016
    Martinez
    18
    Bit of a newbie here - 23,5K gal shotcrete pool, water is in balance and the dead salt cell has recently been replaced and is up and running (YAY!).
    With everything now in place, I'm taking over the cleaning from the pool company. That currently entails skimming the surface, cleaning the filter baskets, and scrubbing the sides and bottom of the pool.
    I rarely have leaves in the pool, and the polaris does a good job of getting up any other leaves or pine needles do get in the bottom.
    I do NOT have a vacuum and was wondering if this is something that I'll need to get in order to ensure that the pool stays in good condition? Am I playing with fire if I don't vacuum regularly?
    The Internet
    ~24,000 gal IG shotcrete pebble, b: 2007
    Pentair: Clean & Clear Plus cart filter, WhisperFlo WFE-6 pump, minimax NT heater
    Taylor K2006 test kit
    Hayward Goldline SWG, TurboCell T15
    Shekkie's Avatar
    Jul 2015
    Grafton, Ohio
    49
    Re: Is vacuuming required?
    I'd say if you notice grit, dirt or whatever accumulating on the bottom then get a vacuum. Otherwise it seems as though your robot is taking care of it.
    33k(ish) gallon, IG, vinyl liner, Pentair IC60 SWG, Pentair Triton II sand filter, 1.5hp Pentair VS pump (SuperFlo), Sta-Rite (Pentair) 400K BTU heater (LP), (2) Pentair LED spa lights, TF-100 test kit w/speed stir
    29,872
    Even a good robot will miss some spots. You need to perform a combination of vacuuming, brushing and running the robot to keep the pool as clean as possible.
    Dave S. - Forum owner
    Aug 2016
    Martinez
    18
    Any suggestions on vacuums that won't totally break the bank? Like I said, I don't have a debris "problem" and the pool is not all that big. In others' experience, how much vacuum is necessary to do a good job?
    The Internet
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,809
    Basically you need a weighted vacuum head, a pole, a long hose, and a skimmer adapter to plug the hose in. I have a vinyl pool and have a vacuum head designed for it so sorry I can't recommend one to you. I too have a Polaris pressure side cleaner and while it does an admirable job it just doesn't get everywhere and i have a few dead spots that it misses. I rarely vacuum however due to little to no debris in the pool. When I have vacuumed I've done it at night with the pool lights on, that's really only when I can see the type of debris that my Polaris misses.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Aug 2015
    Grandy, NC
    131
    OR I have been using this
    Water Tech LVAC100 Swimming Pool Blaster Battery Powered Hoseless Leaf Vacuum
    for the past 3 years and LOVE IT! Around $100 WalMart, Amazon - all you need are 8 AA batteries (I replace mine 1x month) Have 19000 gal AG and don't have to deal with hose, skimmer blocking with leaves, etc. Handles everything that ends up on floor. (wish I knew how to add pic ) Check it out.
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
