Results 1 to 9 of 9
Thread: Faded liner
    Mar 2016
    Chicago,IL
    88
    Faded liner
    After 1 year of having my pool I feel the liner is pretty faded. I pulled out my wedding steps yesterday and there was a significant color difference in that area verse the rest of the pool. It was even worse where the suction cups of the ladder were. Is this natural to see this or is it possible I was running bleach a little higher then I should of?
    Pretty typical results all year
    pH-7.6
    Cya-30
    FC-5
    Ch-100
    TA-140
    Borates-50
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Faded liner
    All liners fade over time, it is hard to say from the photos if this is just normal ageing or if it was a chemical balance issue.
    Mar 2016
    Chicago,IL
    88
    Re: Faded liner
    Yeah the picture makes it look less noticeable then it is. It just appears to me to be mich more faded then it should over a year. If I had an elevated FC level for a week? Would that be the cause?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Re: Faded liner
    If you are keeping FC below shock level for your CYA then chlorine is not fading your liner. FC/CYA Chart
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    328
    Re: Faded liner
    Here's my fading after ten years in full sun. You can see it looks worse from the pictures out the bedroom window than down low. The spot under the steps is where I put a tab before I new better. Don't really care about color, as long as it holds water!
    Before and after of the deck carpet, too.
    joeself7's Library | Photobucket
    edited link
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Casey's Avatar
    SW PA
    10,255
    Re: Faded liner
    Leave a shirt balled up outside, untouched, and see how the sun fades it.
    30,287
    Re: Faded liner
    Significant liner fading at the end of one year is not normal. Yes, one week of overdose of FC can fade it.
    Kept within the guidelines TFP suggests, there should be no fading that you would notice for several years.
    The ink used on your liner may have an affect as well. Inferior ink will give up quicker than others.
    So, there are many factors involved but it sounds like your FC was excessive at some point.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,163
    Re: Faded liner
    That looks like prism bottom or glimmer glass, depending where it came from. Either way it's "printed" on white sheet material... I always try to discourage owners from white sheet.. They are a notably faster fade
    Jan 2010
    Randleman,NC
    620
    Re: Faded liner
    Mine faded this year to.The past 2 liners that I have had.Have faded and Warranty doesn't cover
