Thread: Ants eating tiny holes in liner.....
    Jul 2016
    Jackson, GA
    3
    Angry Ants eating tiny holes in liner.....
    Hello,
    This is my first year with an 24ft round above ground pool and it has not been an easy first year. It first started about 2 months into summer and our pool was leaking. Figured out it was tiny holes that were created by ants. The thing is, we have a pool cove and one of those pool liner pads under the liner as well that is supposed to prevent ants and rocks from getting to the liner... so how are the ants getting to the liner? Its so freaking frustrating because as soon as we patched the already 11 holes, more appeared! We are replacing the liner next spring but I want to get a head start and get some ideas on how to prevent the holes in the new one. Hubby spread some ant killer before the first holes which obviously didn't help and after patching the first holes he spread more ant killer around the pool and more holes appeared.... what are we doing wrong? Any advice would be helpful!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,532
    Re: Ants eating tiny holes in liner.....
    One downside of a well prepared pool base is that it makes and excellent home for ants. Ants can chew threw solid wood, a layer of heavy vinyl will only slow them down slightly. My PB suggested being vigilant about treating the base of the pool multiple times a year to discourage ants from making a home under the pool. When you replace your liner give your self an extra bit of time to treat the area under the pool really well with ant spray.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    pabeader's Avatar
    May 2015
    Dallas Ga
    4,072
    Just a thought. Maybe apply boric acid type ant treatment all around under the base. I know it works around the house but have no direct experience of needing/using it under a pool.
    Bob - Palm Beach by San Juan Pools. approx 5000 gals., Pentair 320 cartridge filter (all new guts installed by me), Goldline SWG, 'New to me' Kreepy Krauly Sand Shark, Intermec 104 Timer Test kit: TF-100 w/Speed Stir
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    340
    Get a pump sprayer. Go here: Do It Yourself Pest Control Products & Supplies | Do My Own Pest Control. BifenXTS is $27.50 per quart and uses 1 qt per 100 gallons of water. It also is a great termiticide. Spray around the liner, though once they are well entrenched under it, getting to them becomes tricky. You may end up replacing the liner anyway if the infestation is too great. If so, treat the ground and pad first, let it dry then keep the perimeter sprayed.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 2hp Pentair pump.
