Thread: Programmable or wifi switches?
    Sep 2016
    Germantown
    6
    This could be a dumb question. I'm not an electrician. My pump is a 1hp AO Smith that is presently on a generic toggle switch. Is it possible to swap that out for a programmable or wifi capable switch? Versus buying a timer or super expensive control center?
    JoyfulNoise's Avatar
    May 2015
    13,399
    Re: Programmable or wifi switches?
    Are you switching 120V or 240V?
    Matt
    May 2015
    13,399
    This is an example of how you could switch a pump remotely -
    Remote Controlled Heavy Duty Switch 60 Amp, 240VAC Relay - SmartHomeUSA.com
    It's basically a 240VAC relay that is activated by a 120VAC control signal. If you power this relay using WiFi plug adapter (like a WeMo switch), then the WiFi controlled outlet will activate or deactivate the relay.
    It's still probably going to cost you ~$200 when all is said and done so I'm not sure how much something like this is going to save you over just installing a standard Intermatic timer box. Not to mention the usual problems with WiFi related gadgets - when the router goes down, nothing works....
    Matt
    22,591
    Do you already have a home automation system that you want to extend to the pump operation?
    If so, then we can figure out how to interface with it. If not then it's probably not going to be any less expensive than a dedicated timer, as Matt said.
    Sep 2016
    Germantown
    6
    I believe it's on 120v. Good points. I'll probably just go with an old trusty Intermatic then. Thanks folks.
    May 2016
    The city, florida
    15
    Quote Originally Posted by dsanford455 View Post
    This is what I use and it works great. I just swapped out my analog timer with this timer.
    Jet.com - Prices Drop As You Shop
