Thread: Algae and the dogs are not happy
    May 2015
    Colorado Springs
    87
    This is my first time getting algae in 2 yrs. Due to health I was not keeping up with the nightly chlorine but the dogs continued to swim. The algae isn't too bad. I have some questions.
    Here are my test numbers
    FC 5
    CC 0.5
    TC 5.5
    500 TA this never changes and it's a factor of our city well water
    CYA 50
    pH 8.2
    When I put in the pool math to check the amount of muriatic acid to change pH the amount of MA changes when I record the TA 500 vs 100. 28 oz of 14 % MA vs 126 oz MA if TA is 500.
    Any idea which way to go? I think my goal is to lower the pH prior to SLAMing. I was told to ignore the TA as I can't change it.
    I bought the bleach and will start adding tonight. It's very cold here at night 45 degrees, days in 80's So there is no climbing in the pool to scrub. I have been using a soft broom on the walls and my usual log pole that has a bristle brush for the middle. I have wedding cake stairs so I will take those out BUT I have a very very sneaky 14 y.o dog who tries to get in the pool as well as a 2 y.o lab who launches over the side where ever. I have the stairs barricaded but I worry he could get in and not out. I have a spare ladder ( no algae nooks and crannies) I can put in maybe to at least give him a platform.
    I usually have the filter run on low 24/7 and only use high for chemical mixing and cleaning. Is that ok to do SLAM on low?
    When I have been vacuuming the pool the brown stuff seems to go right through to the return jet-just a bit. I back washed and rinsed and still the next day see lots of brown crud on the bottom. Because we live on the prairie and the wind blows we expect sand in the pool bottom a bit but this brown stuff from the jet is not making me happy.
    I will be attempting the SLAM, lol best I can. I have a brain problem and it's often hard understand stuff. I will be closing the pool down soon. Last year I closed it very clean and opened it sparkling thank you TFPs. I was proud.
    Any suggestion welcome.
    Teresa
    Used pool 1995 Lomart 18'x48" just installed 7/16/2015, Hayward Power Flo Matrix 1 HP 2 speed pump, 16" Rx Clear Radiant sand filter ( used pea gravel and zeolite) foam wall, polystyrene bottom, liner 25 gauge overlap, TF-100 test kit. Son training for 2018 Paralympics, Hoping for solar heater of some sort. Good chance Labrador will be in pool. Colorado Prairie, 6000 ft elevation high mountain desert, clay soil
    Catanzaro's Avatar
    Jul 2014
    Howell, New Jersey
    1,167
    Re: Algae and the dogs are not happy
    Only put in the lesser of MA and about 4 hours later check PH to see if any changes occurred. If still high, or no change them increase accordingly. You are better not lowering your PH too much by adding to much acid. The TA may affect he amount. Worst case is an extra gallon lost because of trial and error. Your PH should be lowered prior to the SLAM. Thanks
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Frog Mineralizer System (EMPTY) - Hayward Super Pump 2 HP Model # k48m2n111
    Pool Company tests water (NO LONGER) TF-100 TEST KIT
    Date of Build is 11-2013
    May 2015
    Colorado Springs
    87
    The pool is clearing better than I had hoped. I added more bleach to bring it back up to SLAM. It dropped to 16 and by the math it should be 20. I scrubbed walls and vacuumed it once yesterday and today-very tiring. Back washed, rinsed and added more water to pool. The pH is not the best but it's better. I added more muriatic acid.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    1,373
    pH test isn't valid with FC over 10-12.
    35K gallon Krystle Krete (Plaster) - Sand Filter - TF100
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart
    May 2015
    Colorado Springs
    87
    Quote Originally Posted by Mr Bruce View Post
    So that's why I should have adjusted the pH pre SLAM?
    My brain doesn't always work well. So should I assume the pre start pH of 8.2 was accurate and just add Muriatic acid based on that?
    The pool is getting clearer.
    Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    16,876
    It would be better to let FC drop to 9 adjust PH and then resume.
