Thread: Hayward HM250 ED2 Heater "BOOMing" on start up
    Jan 2015
    Nevada
    16
    Got on issue with my pool heater. When the command is sent to start I can hear the ignitor clicking away but it does not "fire" up like normal. After awhile it will go BOOM igniting all the gas from start. Any ideas?
    Custom 12,500 IG Pebbletech pool with attached SPA (Built 1996), Cartridge Filter, Hayward EcoStar Var Speed Pump (junk after 4 yrs) REPLACED with Hayward TRISTAR Dual Speed SP32202EE, SWG Aqua T-Cell-15, Hayward Pro Logic PS-8 Pool Controller, Wireless Base Transmitter, Wireless Remote, Hayward Pool Heater HM250 (1996 manufacture date stamped), Zodiac MAX 8 Pool Cleaner
    Jun 2012
    western NY
    1,557
    Re: Hayward HM250 ED2 Heater "BOOMing" on start up
    Sounds like a good disassembly and cleaning is in order. Probably a clogged up burner tube near the pilot assembly.
    Dan
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    416
    Also clean the gas orifices.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    ps0303's Avatar
    Jul 2011
    FL
    3,495
    If cleaning doesn't fix this, let us know.
    Paul
    http://www.gastekservices.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jan 2015
    Nevada
    16
    Major cleaning effort did the job. Ignition and pilot light works like a charm. I even pulled off the exhaust vent and top then cleaned the copper tubes above the burner which had some major green corrosion and rusty metal pieces. I cleaned all the connections. The pilot light and ignition is buried underneath the unit so it took a little inginuity to get a steel brush that deep. I wanted to do as much as I could before pulling out the burner if that did not solve the issue. All good so far.
