Thread: Sundance Spa Circ Pump Shutting Down While Heater Is Going
    Oct 2015
    Phoenix
    15
    It will do this over and over till it over heats water.
    Isaac-1's Avatar
    SW Louisiana
    6,709
    Re: Sundance Spa Circ Pump Shutting Down While Heater Is Going
    I can't help you on this specific model, but it sounds like it is time for a new circulation pump, I had something similar happen when I first bought my Hot Spring tub (used tub), as it turned out the circulation pump was only running at about half speed.
    Oct 2015
    Phoenix
    15
    No board cuts the power to pump. Checked power coming of board.
    Isaac-1's Avatar
    SW Louisiana
    6,709
    In the case of my tub the flow problem was in the pump itself, pump ran, did not make extra noise, just only had a fraction of the flow it should have put out.
