Thread: Steps on ladder covered in algae
    Bisons's Avatar
    Aug 2016
    Burlington, Ontario
    6
    Pool is clear, look good but the steps are just covered. Brushing doesn't do anything. I took the steps out and really scrubbed them with bleach/water, worked a little but didn't get them white.
    Any tricks to cleaning that up?
    14,000 gallons - oval shape - inground
    Chlorinator - Hayward CL-200 EF
    Sand filter - SwimPro SW-236T
    Pump - Hayward Super Pump C48K2N143B3
    Heater - Solar (roof)
    Catanzaro's Avatar
    Jul 2014
    Howell, New Jersey
    1,167
    Re: Steps on ladder covered in algae
    I would remove the steps again and try Vitamin C tablets and possibly a puck (let it sit for a while). Probably not algae, but staining. You could also try Magic Eraser as this is what I used on my white steps for the scum line (works wonders).
    Have you checked for metals in your water? Do you have City Water or Well Water?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Frog Mineralizer System (EMPTY) - Hayward Super Pump 2 HP Model # k48m2n111
    Pool Company tests water (NO LONGER) TF-100 TEST KIT
    Date of Build is 11-2013
    Bisons's Avatar
    Aug 2016
    Burlington, Ontario
    6
    Quote Originally Posted by Catanzaro View Post
    Thanks, I'll try those.
    Haven't checked for metals. I have city water.
    Seems like staining to me. Did you let it soak in the bleach for a little bit before attempting to brush? If that still doesn't help try putting on some gloves, goggles, and old clothes then scrub it after soaking it in the bleach solution, but still keep it in the solution as you scrub. This usually works for me.
    Aug 2014
    Northern IL
    4,617
    Put some vitamin C tablets in a sock and scrub with that if the other options don't work. It's hard to tell from the pic if the stains are organic or iron staining.
    28,518
    My first idea would be to remove the steps and try "Comet"......scrub it on with a deck brush and rinse.
    Dave S. - Forum owner
