Thread: What's your CYA?
    Aug 2016
    Cincinnati, Oh
    48
    What's your CYA?
    Pool season is winding down here in Cinci, my pool is doing great and pool expenses are way down. As I ponder the important things in life I keep coming back to a question about CYA levels and I'm curious what the levels are in the pools owned by the experts here. I know the ideal range is 30-60 and I *think* I understand the pros and cons of higher versus lower CYA but wanted to hear from others what their levels are and why.
    Thanks
    10,350 In-Ground Vinyl
    Sand filter, 1.5 Pentair Pinnacle
    Municipal water source
    Liquidator
    K2006
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,081
    Re: What's your CYA?
    the primary reason for CYA is to help protect the FC from being destroyed by UV from the sun.
    With autumn on us and winter around the corner, that means less UV from the sun, and it also means lower water temperatures.
    As the temps drop, the algae reproduction slows way down. So, its ok over the cold months to let the CYA get lower than normal recommended levels which is imperative in the hot summer.
    I live in a warm climate and wont close my pool, Im still keeping my CYA and FC at normal level until the water gets down to in the 60's, and then I wont worry about CYA any more until Springtime comes back around. But I will test periodically and add liquid chlorine when the pool needs it.
    Divin Dave,
    May 2016
    Toronto
    130
    70-80
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
