Thread: Closing pool for first time- a few questions
    Jul 2016
    Milwaukee, WI
    14
    Based on the extensive reading I've done on here and google, I:
    - Clean & brush pool
    - I've been doing TFP, so I bring water to shock level & maintain for 24 hrs, running pump
    - Remove ladder
    - Drain water 6" below skimmer
    - Heater: drain it and blow out remaining water w/ shop vac, remove drain plug (not sure where that is, but will check)
    - Remove all fittings for equipment and blow out water
    - Drain cartridge filter, and after blowing out, turn valve to closed or winter (not sure where that is, but will look) and remove pressure gauge
    - Put tube in water & put on winter cover
    Now, for my questions:
    1. I can put a gizmo in the skimmer, but what kind of plugs do I need to buy for the openings I circled on the 2 pictures?
    2. The pump is basically attached to the cartridge, so will it be ok being exposed to the the WI winter?
    3. Can I use regular float tubes to put in middle of pool, for under winter cover?
    4. Should I put a tarp cover over the heater, pump, and cartridge during the winter?
    5. Do I need to turn off the gas line supply during the winter or just leave the handle to turned on (not talking about the electrical switch to turn on heater, but the actual lever that is there for emergency turn off, I'm assuming).
    Thank you for your help! By the way, ignore the landscaping! That's being done next week
    (I have 2 pictures, it wouldn't let me upload the second, so here's the link for second)
    http://i66.tinypic.com/2h7ih5k.jpg
    19,000 gallons AG (18x40)
    Hayward Voyager system w/ 1.5hp Matrix pump
    Install: 8/2016
    Hayward 200,000 Btu NG
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,187
    Re: Closing pool for first time- a few questions
    YOU CAN LEAVE EXPOSED!
    YES, THEY ARE DESIGNED TO BE LEFT OUTDOORS.
    YES, THIS WILL WORK.
    IF YOU WISH, THIS IS ALSO FINE.
    I DEFINITELY WOULD SHUT OFF THE GAS LINE.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jul 2016
    Milwaukee, WI
    14
    Thank you!
