Results 1 to 9 of 9
Thread: Off the Charts FC
    Jun 2013
    Houston, TX
    23
    Off the Charts FC
    I had some yellow algae on the side of my pool and the CYA was 85. I drained some water and started the SLAMING. However, I added enough bleach to get the FC to 35 using the "previous" CYA number, not the CURRENT CYA! My FC is now reading 235!!!! What should I do?
    DeeDee
    24Kgal/IG/Pebble/525sq.ft.CartridgeFilter/1.5 HP Pump/Built 2012
    Mod Squad pooldv's Avatar
    DFW, TX
    24,742
    Re: Off the Charts FC
    The FAS/DPD chlorine test is only good for measuring FC up to 50 ppm. It would take 69 jugs of 8.25% bleach to get your FC to 235. Are you sure you added 69 jugs of bleach to your pool?
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Previous or new CYA number doesn't affect FC readings. They are not directly related, only use the CYA to estimate your FC range.
    Can you shed details on your additions?? How did you test FC @ 235 ppm??
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jun 2013
    Houston, TX
    23
    No, I added 6 gallons of bleach.
    I used my TF100 test kit and it took 47 drops of R-0871 to get it clear, and then I multiplied it by 0.5
    My CYA is now 50.
    DeeDee
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    That's 23.5. Slightly over SLAM value, no reason to worry, much less panic.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2013
    Houston, TX
    23
    Oh my goodness!! I forgot to add my decimal...DUH!!!
    Thank you!!
    DeeDee
    DFW, TX
    24,742
    LOL! Alright, glad we got that sorted out. SLAM on!
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    50
    No worries! Keep going! Keep on brushing and filtering. You'll get there.
    22,400 gal; in-ground gunite rectangle, vinyl liner; 3.5'-8' depth; Chlorine; auto cover; Hayward Pump and Sand Filter; Hayward Electric Heatpro; diving board; 3 sidewall fountains; open mid May thru mid October; built 2011; Taylor K-2006C FAS-DPD Test Kit
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,183
    Just remember not to quit until your SLAM is complete, and it takes more than one day.
