Thread: Pool got closed, didn't check here first
    Triplejnj's Avatar
    May 2015
    Jackson, NJ
    32
    Hey gang- religiously followed the TFP method and had a crystal clear sparkling pool pretty much the entire summer.
    Just had the pool closed over the weekend and after reading some threads here, things were done a little differently.
    1) Water was drained to just below the skimmers, not below the returns
    2) No algaecide or anti-freeze was added to the pool before draining and blowing the lines. There was some antifreeze added to each skimmer around the gizzmo.
    Should I be concerned?
    I do have one of the better mesh covers that supposedly block out UV
    Tom
    16k freeform IG vinyl | Hayward 2hp pump, 300lb sand filter, 250k btu heater | AquaRite SWG | Installed October, 2014
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    749
    Re: Pool got closed, didn't check here first
    FWIW, I watched my "old" pool guy close my then 'new to me pool' that very way several seasons ago and it was just fine. Provided the returns were blown out well and plugged, I don't see any issues.
    One thing you could add now probably is an empty capped bleach or anti-freeze bottle to the skimmer. If you get water/ice in the skimmer, the bottle will collapse under the freezing ice before anything breaks.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Catanzaro's Avatar
    Jul 2014
    Howell, New Jersey
    1,754
    I only drain my water below the skimmers and remove almost 99.9% of all the water in the lines. The returns are blown out under water. No Anti-Freeze in any of my piping. The Gizmo will do the trick, but at Pool Tool states, the extra bottle is never a bad idea.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Triplejnj's Avatar
    May 2015
    Jackson, NJ
    32
    Thanks guys, and neighbor! Never heard of the empty bottles in skimmer, but makes sense. Catanzaro, sounds like a Pool Town build?
    Tom
    Aug 2016
    Berks County, PA
    99
    Quote Originally Posted by Triplejnj View Post
    I also always put an empty gallon container of antifreeze in the skimmer pot. Sometimes when I check things during the winter, the ice is completely wrapped tight against the plastic, so I like how it serves as a bit of an expansion piece rather than the ice being allowed to fill the whole skimmer pot and potentially cracking something.
    12,500 gallon gunite, original construction 1989, renovation 2014 using quartz plaster finish. Baquacil-treated pool.
