Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Handrail is stuck
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    Handrail is stuck
    I got my ladder out with no problem, but the handrail over the step is super stuck......like its welded in. The bolts that hold the slide thing on it have dropped, so they aren't the problem. Any suggestions to get this out???
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    756
    Re: Handrail is stuck
    Slow but steady pressure. Try turning it back and forth as you lift. Sounds like you are sure that the anchor wedge dropped, but be sure the bolt is backed all the way out then tap it down if necessary. There was one person that posted a similar situation and was able to free it by using a hydraulic car jack and wood block under the handle. Just be careful not to apply to much pressure.
    You may have tried all this, so sorry if it is repetitive.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    No thanks for any advice. I have tried all this so far, the pressure and stuff. I am sure the wedge has dropped, as I can put the bolt back in, and raise it up and down freely. I did have to tap it down when I first started. I was about ready to get the jack out, but I figured if I cracked the concrete I was screwed.
    Mark
    Pool Tool's Avatar
    May 2014
    756
    You'll probably bend the handle before you crack the concrete, but still not good. I am assuming the handle will interfere with your winter cover?
    PB Blaster or WD40 may help free it up as well.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    Yes it will interfere with cover for sure. I didn't have any problem last year, but pool was finished first week of September last year, so it was only in there for 5-6 weeks. This is the first full year of having the pool. I got WD40 working in there now, but don't seem to be helping any. I am hoping my big strong step son maybe the answer....HA!
    Mark
    Pool Tool's Avatar
    May 2014
    756
    Yup, he should help. It really is just stubborn and needs some motivating...the handle not the step son.
    Spinning it should let you apply more force to break it free vs lifting it. It is just too hard to "lift" it with out tilting it. It will come out eventually. I do recommend PB Blaster over WD40.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    It has two posts on the hand rail. Spinning is not an option. You're right.....it will come out eventually.....LOL, one way or the other!!!!
    Mark
    Mod Squad JohnT's Avatar
    SW Indiana
    9,171
    Quote Originally Posted by kywildcats View Post
    When I grab the end of mine and move it to the side the posts rotate in the sockets. Maybe some gentle twisting on the end.
    Apr 2015
    South Central PA
    297
    I just took mine out yesterday. Some rocking side to side and forward/backward eventually freed it up enough to come out.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    30,315
    I used a large rubber mallet. You can hit it pretty hard about 6" above the socket and with upward pressure, mine released.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    WOW......I have tried everything except a jack to get this thing out. 3 men swinging, pulling, lifting. PB Blaster, rubber mallet, 2x4 as leverage and it is still standing there.
    Mark
    Sep 2016
    Escondido/CA
    636
    Is there a way to get some compressed air into it? Probably a long shot, but if it is a 3" tube, that is 1.5^2*Pi=7*150psi would yield about a thousand pounds exactly in the direction you want, if somehow it was sealed [which it probably is not], but if you can keep up with the leak, you will get the 1000 lb of force. Even if that doesn't break it lose, now the other options may work.
    If you figure out some way to do this, be careful. You could turn that railing into a rocket, so have something to catch it if/when it lets go.
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    30,315
    The bottom of that rail is not sealed so the above idea won't work on several levels.
    Most of all, it is very unsafe and should be disregarded.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    I didn't try that method, Dave. I have tried every other method though, and the rail is still standing tall. I guess I am going to figure out a way to cover the pool with it in there.
    Mark
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,203
    My handrail has 2 inserts that are close together. This year, one of the supports fell in. What I did after hot water is twist back and forth. Yours may be jammed because the base is bent and something is wedging it in. Twisting in a 360 degree fashion may work (hopefully) as it worked for me, unless what is wedged in there is restricting this as well (If this makes sense). I believe it is your only solution to get it out.
    Last year, I had so many problems with the steps, that this year, every 2 weeks the steps were removed, cleaned and I added some elbow grease. I guess will have to the same for the steps because it was very difficult.
    Good luck with everything and please keep us posted!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Sep 2016
    Escondido/CA
    636
    Bummer about the no sealing. Good put about this also creating a rocket. I'd certainly still do it, but I'm probably a bit of a cowboy when it comes to taking calculated risks.
    If it is mostly sealed, a hydraulic (pressurized water vs air) might be a method to break it loses also.
    Major_in_MS's Avatar
    Jul 2016
    Florence, MS
    94
    Usually it is sand or grit that gets wedged in there. Do you have a pressure washer that you can use. A high pressure washout of that socket may be all it needs to release your handrail.
    24,200 gal., IG vinyl, 18' x 36' rectangular, average depth 5'. K-2006C
    Jandy SFTM22 sand filter, 1.65 HP PureLine VS Pump, Doheny's Discovery Robot.
    One skimmer, one main drain, two eyeball jets, and one return from the booster pump.
    One wife of 28 years (schoolteacher, first grade), four kids (ages 16,18,19, and 21).
    I work night shift (Pediatric RN) so most of my posts will be during the night.
    Jul 2016
    Florence, MS
    94
    Also, try pouring a coke into the socket. The acid in the soda will help dissolve any salt corrosion that may be causing problems.
    Sep 2016
    Escondido/CA
    636
    Quote Originally Posted by Major_in_MS View Post
    Or maybe the opposite--a shop vac to pull out material?
    I'm also thinking about a lever and something to grip the pipe. If you were Got lucky, and found sched 80pvc, you could split it, and glue rubber to each half. Then hose clamp the two halves around the pipe. Now use pvc cement to glue on wings on each half, and this could make a good fulcrum for a lever. Maybe a couple of 2x6s with a spacer the Same diameter as the pipe.
  20. Back To Top    #20
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    572
    I never thought about the pressure washer, I will give that a try this afternoon, after I pour some Coke on it and let it sit awhile.
    xyz.........you must be an engineer of some sort..........HA! Thanks for the ideas though~
    Mark
