Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: I think I am on the right track ?
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I had my water balanced earlier in the year and the rains hit so I didnt look after it as I should because every night when it was time to check the pool it was raining.
    With that my CYA got diluted and disappeared and with adding no bleach an algae bloom started, imagine that!
    I have again started to get my water balanced but it seems to take forever this time. Right now the water is that blueish gray tint and here are my results from this morning.
    FC 12
    CC 1
    TC 13
    TA 60 ( little low)
    CH 50
    CYA 30 - 35
    Temp 76
    Been brushing and back washing. How long normally should it take to clear your water after the algae is dead ? My other question is how long does filter sand last ? (I think this is our 4th year with this sand) Should we be thinking about changing it after the season is over ?
    Water has been this color for about 4 days now .....what am I missing ?
    I have attached a picture so you can see the color of the water.
    water color
    water color 2
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Jan 2009
    Cupertino, CA
    1,966
    Re: I think I am on the right track ?
    Word is it can take a sand filter a week to clear up a really cloudy pool. Adding 1/2 lb DE to the sand filter could speed that up.
    CC 1 means you're not done shocking, yet.
    --paulr
    BBB "Intermediate Swimmer"
    Aug 2007
    Eastern Canada
    54
    Quote Originally Posted by TizMe
    My sand is 24 years old, and still working fine, so I would not worry about this after only four.
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
    30,420
    TM,
    Get your FC back up to shock value and keep it there until your pool clears. It will go much faster if you keep adequate levels of FC in the pool.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Duraleigh I have been keeping my FC level at shock level (and a little bit higher, I dont like 1/2 bottles of bleach laying around) for about a week now , late at night and first thing in the morning before I leave for work. I have been doing this for about a week now just this time it seems like its taking forever to clear up !
    I guess I need to buy some POP on my next bleach run as well !!
    Les
    Helpful Links:
    30,420
    With your CYA, I wouldn't hesitate to run it on up to 16-20ppm and hold it there for a day or two. It may be just the kick you need to see some improvement and it won't hurt a thing.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I will start that in the morning I have already made my pool trek for the night lol
    Les
    Helpful Links:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    And the frustration sets in !! I have been shocking the pool to 20ppm for a few days (since the morning of 06/08) now and not really seeing and improvement however with last nights bleach addition I didnt have enough on hand so I put in what I had. Calculator called for 4 - 96 oz bottles and I had 2. Will it help adding some DE to the filter as PaulR suggested or should I wait a few more days and see what happens. The wife wants to drain it and start over again, she is wanting in it bad !
    Les
    Helpful Links:
    Have you done an overnight FC loss test? There are two possibilities. Either you are failing to kill the algae for some mysterious reason, or the filter is not working correctly. The overnight FC loss test will tell you if there is still algae. If there isn't then there must be something up with the filter.
    30,420
    Tiz,
    Jason is spot-on. You really need to do the overnight FC loss test to prove to yourself what you need to do.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I just did my chlorine addition for the night about an hour ago so I will go see what the FC count is now and retest it in the morning. What could be the problem with the filter ? The water was clear earlier in the spring so I assume its working properly. When I do my back washing there is stuff coming out the discharge pipe so wouldnt that mean it is trapping particles of junk ? The only thing I have not done is vacuum the pool, but done a lot of brushing !!
    Addition to post ...
    FC was 23.5
    After thought ....
    As an after thought our solar cover has begun breaking up and I have noticed the blue bubble tops in the skimmer basket. Is there a chemical inside those bubbles this that could be causing this ?
    Les
    Helpful Links:
    There are lots of possibilities with the filter, though none of them are especially likely. Lets make sure the algae is all dead first, and then worry about the filter.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Did my FC test this morning and my results were,
    23.5 (FC from test last night)
    20.5 (FC from test this morning)
    1.0 (CC)
    21.5 (TC)
    I did not add any chlorine to the water this morning because I wasnt sure what approach you were going to have me take . The water looking at it during day light is still that blue/gray color and you can not see the bottom of the pool . I also edited my last post after a few people responded so I am not sure if you saw what was said.
    Les
    Helpful Links:
    May 2009
    Charlotte, NC
    12
    I am no expert, but have been through the frustratingly slow pace of pool clearing that you have.
    My experience is that things started to change quickly after I vacuumed to waste at least 2 times, added DE to sand filter, and vacuumed normal at least once a day.
    Then my solar cover helped with both day and night FC loss, although I am not sure how it helps with night loss, but I saw a drop. Saved on bleach.
    I think helping the filteration ( especially a sand filter) along is important. For me raising the Cl levels higher (above 15, with CYA about 45)) did not clear the water any faster.
    A lot of POP did
    Good luck
    RV
    Above Ground 14.2 K Gallon, vinyl, Baquapure sand filter, 2.5 HP pump, K-2006 test kit
    Alright, it is algae and the filter is presumably fine.
    I suggest raising your shock level FC target to at least 15, though I see you are already well over that, and doing as much vacuuming as you can. If there is any substantial amount of debris on the bottom of the pool the algae can hide out there to avoid most of the effects of high chlorine levels. Vacuum up everything you can, even if you can't see the bottom. You should also brush the entire pool at least once a day.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Could I put our Zippy pool cleaner in and let it run or is vacuuming better ? Vacuuming is about the only thing I have not done this year so far. If you suggest vacuuming should I vacuum to waste or just with the filter running ?
    Also should I continue to shock to 20 ppm as Dave suggested or can I drop it to 15 ?
    Les
    Helpful Links:
    You can shock to 20 if you want. I wouldn't normally go that high, but you have been having problems and it shouldn't hurt anything.
    I would give the pool cleaner a try. If it is the kind with a debris bag, you may need to clean it out much more often than usual. Depending on how much debris you have down there, it may clog up so quickly that it is almost useless, in which case you will need to switch to manual vacuuming.
    If you manually vacuum and there is really a lot of debris on the bottom then vacuuming to waste is a good idea. Regular vacuuming in those conditions will fill up the filter quickly, raising the filter pressure and killing the water flow.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Our cleaner is the "Zippy" by barracuda. It has a debris collector but not a bag. I will throw it in tonight when I get in from work and see what we get. If there seems to be a lot of debris I will switch to the vacuum and manually do it
    Les
    Helpful Links:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    The pool cleaner is in and you can just barely see it on the bottom of the pool so I think we are making some progress. Also I could see a patch of debris in the center of the pool so hopefully the cleaner will pick it up.
    Les
    Helpful Links:
  20. Back To Top    #20
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Ok,
    "Zippy" has been in for about 5 hours and there wasnt very many leaves in the pool however it did pick up tons of dirt and other things off trees around the pool. I was just out getting my water sample for my FC test and I took Zippy out and gave the pool bottom a good brushing. You can actually make out the brush on the bottom of the pool !!
    Tonights test ...
    FC 11.5
    CC 1.0
    TC 12.5
    Les
    Helpful Links:
