Thread: Clean-out pipes after pool is closed
    May 2016
    St Paul, MN
    44
    Pool will be closed tomorrow. Our lines are blown out, because we're in Minnesota. Once that is done, is it possible or advisable for me to take any of the pipes apart? I'd like to check the pipes into our heater. It consistently refuses to fire because the pressure isn't high enough, even after I've backwashed and cleaned the filter. I'm wondering if there's some debris that's blocking the flow to the heater. We've replaced every part on the heater; it should work perfectly. But the pressure switch doesn't seem to let it fire.
    Kelly
    40,000 IG vinyl pool / sand filter / SWG / Intelliflow VS / TK-2006 / well water / sunlight blocking cover
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    15,001
    Re: Clean-out pipes after pool is closed
    As far as I know its the amount of flow, not pressure your heater requires to operate. Its purely guessing, but I would look to the filter first for obstructions of flow. Perhaps you have to little water coming through the laterals of the filter? Perhaps the heater itself has a clog internally? Someone else will likely have some other reasons, but these are the first that come to mind for me.
    Essential Links:
    May 2016
    St Paul, MN
    44
    Our pool set-up is filter - SWG - heater. So maybe that's the problem? There's not enough flow coming from the SWG to allow the heater to fire? If so, not sure what I can do about that.
