Thread: Question about numbers and daytime FC loss
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    I'm in Oklahoma and the weather here has turned pretty hot. Our pool gets full sun from 8am-8pm. Look at my numbers below and let me know if the daytime loss in FC is normal?? The pool water is clear and sparkling right now.
    Day 1:
    FC 6
    CC 0.5
    TC 6.5
    PH 7.8
    TA 200
    CYA 40
    Temp 88F
    Day 2:
    FC 3.5
    CC 0
    TC 3.5
    PH 7.0 (I'm lowering my TA and aerating)
    TA 160
    CYA 50
    Temp 92F
    Thanks again,
    Alan
    30ft AG
    Alan
    30ft AGP
    2hp pump
    TFTestkits ,Pool Calculator, Pool School
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Question about numbers and daytime FC loss
    did you add cya or just a test variance between 40 and 50ppm? some people with full sun like that find 60ppm works a bit better. the average daily loss given out around here is 2ppm, so my guess is that 2.5ppm in full sun would be normal. I think if you put a solar cover on you would lose noticeably less. good idea on aeration.
    irishal's Avatar
    May 2009
    Edmond, OK
    37
    Thanks for reply. I am in process of adding CYA. My hope is to get it up there in the 60-70 range. Wanted to make sure that sort of loss is normal.
    Alan
    30ft AGP
    2hp pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I wouldn't go over 60 if I were you based on what I've read here and seen recommended by the mods. I'm at 70 and wish I was at 50.
    30,426
    Hey. Alan,
    Yeah, reebok offers up some good advice. 70 is hard to back away from. 50-60 CYA even in full sun probably makes more sense. Either way, it's a bit of a gray area but it is very easy to increase in the future and a PITA if you need to go back down.
    BTW, your numbers and your management of your pool water looks very good. I suspect your water looks just as good.
