Thread: Pentair 400K Master Temp intermittent issues
    Jan 2011
    Richmond, Texas
    595
    Hi All -
    I have a 400K Natural Gas Master Temp heater. Lately I have had issues where it will go through the normal sequence of start up and start heating only to shut back off withing a min or two with service light indicator to come on. If I shut it off and turn it back on it will usually come back on and heat as normal. Sometimes I have to do this three or four times. This seems to happen when it is wet outside and we have had a bunch of rain again this year. If it hasn't rained for a few days there are no issues. Every time this happens it is dripping wet and of course I don't want to take the panel off to read the error codes in the mud. Any ideas what could be causing this?
    Thanks
    Flippy
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    ps0303's Avatar
    Jul 2011
    FL
    3,805
    Re: Pentair 400K Master Temp intermittent issues
    You really need to read the error code. It will provide you a starting place to determine what is wrong and in some cases tells you exactly what to do.
    How old is the unit?
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jan 2011
    Richmond, Texas
    595
    Manufacture date is 2/2009 and we moved in 12/2010. I guess I will have to break down the next time it happens and get a little muddy.
    Jan 2011
    Richmond, Texas
    595
    It finally happened again. The only led lit on the back was LED 11 and I think that is the service indicator LED. I shut it off and turned it back on and it worked with no issues. This only happens when it has rained the same day. Any ideas?
