Thread: Pool winterization, first time, question about suction limiting vent pipe
    Jun 2014
    New Jersey
    1
    Hi,
    I decided to learn how to close and winterize my pool for the first time. Everything went well, bought an air blower that hooked to one of the skimmers and easily cleared out the water from the other skimmer, all the returns, and the bottom return. My question is with the main drain. I have a suction limiting vent pipe, and once all my returns were plugged the vent pipe started shooting out water. I thought this was great until after 20 minutes it wasn't stopping. Eventually i gave up and just plugged the vent pipe and saw bubbles coming from the main drain, i went ahead a locked the valve to seal the air to the main drain.
    My question is, is this enough to ensure all the water was ejected from the vent pipe?
    How do i make sure the vent pipe is cleared?
    Thanks
    Felix
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool winterization, first time, question about suction limiting vent pipe
    I'm not sure I know what is meant by a suction limiting vent pipe. Do you mean that your main drain is linked to your skimmer? Where is the vent pipe located?
    Isolated Spa - 345 Gallons
