Thread: New Pool Owner Question about equipment condition
    Sep 2016
    San Diego, CA
    3
    Good Morning,
    Sorry I don't mean to be vague but I was wonder if someone could tell me about the condition and what type of maintenance I'm looking at on my pool I just purchased. It's a salt water pool and I have some pictures of the equipment, its about 10X30 standard size.
    Mod Squad tim5055's Avatar
    May 2014
    Columbia, SC
    8,528
    Re: New Pool Owner Question about equipment condition
    Welcome to TFP. How does the water look? Is all the equipment working like you think it should be?
    TFP Moderator 39 X 18 23,000(ish) freeform gunite; built 2007ish; Pentair Triton II TR100 600lb Sand filter; 2 HP Pentair pump with 2.2 HP AO Smith single speed motor; 2 skimmers, 1 main drain, 4 returns w/waterfall, Stenner 45MHP2 3GPD running@ 60% - 15 gal Tank; heated by the sun CYA 200+ when I started - 50 now. Dolphin Supreme M5 Pool Cleaner. Hot Springs SX Spa, 285 gallon
    Sep 2016
    San Diego, CA
    3
    Sorry I was going to post more pictures but ran out of storage on the site. Yes the water looks very crystal clear and the equipment seems to be functioning normal. The only thing I just don't know is when it first turns on it does make a whine that settles down and turns into a nice very quite running system.
    Sep 2016
    San Diego, CA
    3
    I was also seeking a second opinion on my gear and if this is a good setup, anything I should add?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    27,100
    Hi! You can add more pics two ways:
    -become a supporting member-more pics, tax deductible, discount on good test kit, discount at IYOPOOL.com, helps us keep the lights on
    -photo bucket using the IMG code.
    I see a test kit on the wall. Do you know which test kit it is? Have you tested the water?
    Do you know what kind of filter you have?
    Sorry for more questions but it will help us get you up to speed on your pool.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    Quote Originally Posted by IowaToyotas View Post
    You may have a variable speed pump. If so, its not uncommon for it to come up in "prime" mode, which is the highest speed, and once primed, set itself to a lower speed. My pump is pretty loud when priming, but at 1400 RPM can't hear it from a short distance away.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
