Thread: So ticked at pool company
    May 2015
    TN
    295
    As some of you remember I had major issues when I took off my cover for the Spring. My walls had caved in deep end. I had sand bottom with vinyl liner. Pool company came and poured pool crete and replaced liner. Around 3k to fix. Now, I have numerous spots of concrete pieces that are pushing thru liner. They said they came and fixed and they did not. Also , I was just standing close to the wall, about 12 inches or so and I felt my foot give. Now there is a hOle about 3 inches in diameter. Anyone have a clue what happened there? I am so ill. That was a lot of money
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,267
    Re: So ticked at pool company
    Any idea what your water table is there? Were you in an area near where fraking or other mining operations are going on?
    Love TFP? Become a
    TFP Supporter!
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    So sorry for this. Could be from erosion - supporting soil washing away. Did you possibly have an ongoing leak before this? Is the pool higher in elevation than the reset of the area around it (by at least a few inches)? When it rains, is there any run off from other sources near the pool?
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    29,289
    OH NO! Do you have a pic?
    I think Z might be on the right track with her questions.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Agree, I think we need to see some pics of the pool and area.
    May 2015
    TN
    295
    They came today. Said it was a thin spot in the pool crete. He said it was fine for now. Just watch it and if it gets worse they will drain down and peel liner back and fix it
