Results 1 to 10 of 10
Thread: Turbidity issue
    hAltonJones's Avatar
    Sep 2014
    Scottsdale, AZ
    21
    Question Turbidity issue
    I've been caring for my pool water for a couple of years. It's normally so clear, you have to look twice to be sure there's water in the pool. However, when it rains heavily, the pool takes a hit. About three weeks ago, I had an algae bloom - not too bad - but bad enough. The chlorine level was low, but not depleted.
    I shocked the pool and for the past couple weeks, I've had chlorine levels high enough to do the white laundry in the pool. All I'd need is a bit of starch. Still a hint of algae, but mostly under control.
    The problem is turbidity. The pool water seems to be rather turbid. I can see the bottom of the pool (eight feet), but it's not close to normal. The filter seems to be in "normal" condition. The vacuum is gleefully running all over the pool.
    Any thoughts?
    Howard Jones
    16,000 gal IG
    1 hp Sta-rite
    Scottsdale, AZ
    JoyfulNoise's Avatar
    May 2015
    13,399
    Re: Turbidity issue
    What kind of filter do you have?
    If you've followed the SLAM procedure for your pool, then you'll eventually reach the stage in the process where all of the algae is dead and your filter is simply taking time to clear the water. Sand filters are very slow at this stage of the process but can be "goosed" with a little DE to help speed up the clarifying process. Cartridge and DE filters are faster at clearing the dead algae but they will usually load up quickly and require a lot of backwashing to keep up the filtration.
    At this point, it's just time...(brushing and vacuuming help too....)
    Matt
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Turbidity issue
    You said you shocked your pool. What type of chlorine are you using? What are you keeping your fc at?
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    Sep 2014
    Scottsdale, AZ
    21
    Re: Turbidity issue
    In this instance, I used CLOROX brand "Pool and Spa Shock PLUS". Sodium dicloro-s.triazinetrione. Free chlorine is 20 to 25 ppm.
    Howard Jones
    16,000 gal IG
    1 hp Sta-rite
    Scottsdale, AZ
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Turbidity issue
    You are adding extra gunk by not using liquid chlorine. You are also adding cya.
    VinDeeLoo
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Re: Turbidity issue
    I have had the same problem with turbidity when using powdered shock instead of liquid chlorine or bleach.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Turbidity issue
    You need to check your cya.
    VinDeeLoo
    Sep 2014
    Scottsdale, AZ
    21
    Re: Turbidity issue
    CYA is no doubt running high. I would expect a commercial shock formulation to anticipate that problem, but I'll pay closer attention to it in the future. Thanks for the comments.
    Howard Jones
    16,000 gal IG
    1 hp Sta-rite
    Scottsdale, AZ
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,798
    Re: Turbidity issue
    Hi Halton. I see you do have a post history here, but I'm not sure you've yet accessed the TFP method of pool care. Its based on testing with a kit that can read cya and high FC (Taylor k2006 or TFT-100 at TFTestkits.net) so that you dial in the correct FC/CYA Chart to avoid ever getting algae, or if you do, and in your case, following the SLAM protocol.
    I've provided the links so you can refresh a bit and get back to sparkly clear water. Cheers to clear!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    triptyx's Avatar
    Apr 2016
    1,449
    Re: Turbidity issue
    Quote Originally Posted by hAltonJones View Post
    They do not "anticipate" that problem. In fact, for pool owners such as you and me who live in arid climates, they massively exacerbate the problem since we do not partially drain and close our pools at the end of the season, and do not (normally) get rain measured in feet that can exchange water and keep the CYA levels under control. This results in a pool with 200+ CYA, and it seems like no amount of chlorine you add can get rid of the resultant algae. To give you an idea, when I purchased my house last April, the pool that came with it had around 300ppm of CYA. I had to maintain nearly 25ppm FC just to keep algae from growing! The levels of chlorine it would have taken for me to get rid of algae would have been astronomical. Luckily the pool was clear, so I was able to drain/refill it, and go to liquid chlorine to keep the CYA in check.
    Solid chlorine just about always adds either CYA or Calcium to your pool. Dichlor is CYA - and if your CYA is high, even 20-25 FC may not be enough to get rid of algae. Saying that you have "a hint of algae" means two things. 1: You have algae, any lapse at all in maintaining the correct levels will result in an out of control pool situation for you. There is no such thing as "a hint of algae" - if you can see it, you have a ticking time bomb. And 2: A hint of algae means a pool that may not be sanitized, allowing bacteria and viruses to survive to infect people who are swimming.
    Please
    , take a minute to really read through pool school and understand it, and get some correct numbers from your own, trustworthy, testing kit, so that we can help you to figure out how to get your pool back to awesome.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
