Results 1 to 12 of 12
Thread: Question about covering the pool equipment
    Jun 2016
    Pittsford, NY
    23
    My pool equipment (filter, heater, and pump) is all located outside at the side of the house under a cover of some trees and bushes. This has made it a bit of a pain to access them during the summer, but Im thinking it will provide some protection during the winter.
    My question is - Is it recommended to get actual covers for any or all of these pieces of equipment? If so, can anyone recommend what kind of cover?
    In-ground (24x40) vinyl pool (~25k gallons), Pentair Clean and Clear Plus cartridge filter (Model CC420P - 150 gpm), Pentair 1.5 HP pump, Pentair MasterTemp 250 Heater. TF100 test Kit.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Question about covering the pool equipment
    I put my Pump in the Garage and cover all the rest of the equipment with a tarp. I also put some mouse baits in the heater as they like to make it a winter home.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,274
    I have a good sized grill cover that I cut a split in to go over one pipe and it covers my pump and filter. Tarps are cheap, Tie or weight them down.
    May 2016
    Troy IL
    467
    despite what all of the others have said, no I don't think it is recommended. You can do it if you want to, but make sure you have enough air movement under that tarp to prevent trapping water and creating rust problems. I don't cover my BBQ grill for the same reason. In my experience, it's held up longer without one.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by camueller View Post
    Well after 20 years of covering the equipment i have yet to experience any rusting problems.
    My #1 problem has been mice eating up the combustion chamber of the heater, which is very hard to find & cost big $'s.
    I also dont cover my BBQ, but its because i use it all year round!
    Aug 2013
    Chicopee, MA
    43
    It's been suggested to me by local exterminator, to use softener sheets or oil of peppermint to stop the mice. According to him mice are allergic to whatever is in the sheets and the peppermint. Every year they make a huge nest in the motor compartment of riding lawm mower. Not since I lay a few sheets on top of motor
    POOL-24ft Above ground, Vinyl 16000 gal
    FILTER-Hayward EC-40 DE filter
    TEST KIT- Taylor -K2006
    Dolphin Robot Cleaner S50
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    562
    Quote Originally Posted by EVChargeGuy View Post
    I saw a snake this summer underneath the heater (heater wasn't running). It seemed like he was just sleeping under it. Maybe he'd just polished off a mouse.
    Quote Originally Posted by arbrey View Post
    Thanks for the info. I was thinking mothballs but I like your method better.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Aug 2016
    Berks County, PA
    132
    Quote Originally Posted by skinpath View Post
    My pool equipment (filter, heater, and pump) is all located outside at the side of the house under a cover of some trees and bushes. This has made it a bit of a pain to access them during the summer, but I’m thinking it will provide some protection during the winter.
    A few years ago I came across a guy online who custom makes covers for pool pumps and heaters, etc. So I sent him all the measurements and so forth and he made these really nice covers with velcro straps, etc. that fit well over the top of the heater and pump. He even had little cutaways in the material where the PVC line comes into the pump, so I was quite impressed with the detail.
    I don't disconnect my pump and take it inside. Not that it isn't a good idea to do so, but I just don't bother with it and have never had any problems the following spring. What I like about the cover on the heater especially is that when the blizzards and snow storms come, I don't have a foot or two of snow right on the open top area of the heater where the fan is. Of course, even with the pump covered, the entire area including the filter occasionally gets completely buried under feet of snow and ice....sometimes for months at a time. Prior to finding the guy who makes the covers, I used to just cut a piece of old solid-mesh winter pool cover that I had, put it over the top of the heater, and tie pieces of twine all around the sides and across the top to hold it in place. As to how necessary it truly is to cover equipment, I really can't say.
    12,500 gallon gunite, original construction 1989, renovation 2014 using quartz plaster finish. Baquacil-treated pool.
    Jun 2016
    Pittsford, NY
    23
    Hi all - thanks for all your suggestions, especially about the mice. I'll definitely get some of that peppermint oil or use drier sheets.
    It's also good to know that if I don't get around to covering the equipment it won't spontaneously combust. It does get some cover from the surrounding trees, so it should do better than just sitting out in the open.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    My raypak manual says not to cover it.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Aug 2016
    Pittsburgh PA
    316
    All HVAC companies will tell you NOT to cover your outside units - for all the reasons mentioned above. It won't dry out properly and it creates a nice space for mice to hide for the winter (and wires to chew on while in hiding).
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,215
    & when mothballs sublimate in heater - you get a residue on contacts..
