Thread: Water table question
    Jun 2016
    Pittsford, NY
    23
    I'm starting to work on a plan to close my pool.
    Some of the posts I read talk about taking into consideration the level of the water table when lowering the pool water level for closing.
    My question is - how do I figure out the level of my water table and what is "too high"?
    I don't have a well and there is no separate hole near the pool that some posts have mentioned.
    I do have a passive sump pump drain in the basement which has some water in it. Just eyeballing the level of that water would put it at or below the level of the main drain in the deep end of the pool (about 8.5 feet deep relative to the top of the liner). Obviously this would not be too high, but I just don't know if this is a good indication of the water table.
    In-ground (24x40) vinyl pool (~25k gallons), Pentair Clean and Clear Plus cartridge filter (Model CC420P - 150 gpm), Pentair 1.5 HP pump, Pentair MasterTemp 250 Heater. TF100 test Kit.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,182
    Re: Water table question
    Quote Originally Posted by skinpath View Post
    I would contact the township to determine if you have high water tables. Ask some neighbors as well. This is not my specialty. Although I will tell you that lowering your water 2" below the skimmer should not do any harm. You can easily close your return jets with the black rubber plugs under water. IMHO, leaving water in the pool also insulates its surroundings. My water is below the skimmer (1") and I was able to clear out the main drain almost 100% (vacuum and blowing out lines). My solid tarp usually fills up with a lot of water before the first true cold spell and only a few inches at most freeze on the surface.
    What is the frost line in NY? Some parts of NY become real cold right after the summer. Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2016
    Pittsford, NY
    23
    It's hard to find a definitive answer on the frost line, since upstate New York varies so much, but it looks like in my area the frost line is in the 36-48 inch range.
    Frankly, that sounds pretty deep - should I expect my water to freeze 3-4 feet from the surface of the water, or will the ground surrounding the pool provide some heat transfer and it will only freeze 3-4 feet from the surface of the pool?
    Catanzaro's Avatar
    Jul 2014
    2,182
    I feel the ground surrounding will provide some heat transfer. I know the surface water under cover will not freeze about 1" from the liner. There must be too much heat coming from the pool walls.
