Thread: Is this polyquat 60?
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    46
    I received 3 quarts of this from my PB (along with dichlor multishock, tri-chlor tabs, "stabilized chlorinating concentrate granular," some ph up, clear blue clarifier, metal sequestrant, etc.) as part of the regimen he prescribed.
    I haven't used any of it other than the tabs for a couple of weeks until my CYA came up to about 40.
    Is this infact the poly 60 that I would use when closing? Says "poly" -blah blah blah... 60%, but I don't want to jump to conclusions...
    Thanks
    16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    JoyfulNoise's Avatar
    May 2015
    6,837
    Re: Is this polyquat 60?
    Yup. That's Polyquat-60
    Matt
    16k IG PebbleTec pool, 650gal spa, spillway and waterfall, 3HP IntelliFlo VS / 1.5HP WhisperFlo, Pentair QuadDE-100 filter, IC40 SWCG, MasterTemp 400k BTU/hr NG heater, KreepyKrauly suction-side cleaner, EasyTouch controls, city water, K-1001, K-2006 and K-1766 test kits, Mannitol test for borates
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    46
    Thanks!
    May 2015
    6,837
    You're welcome.
    Matt
