Thread: Pool heater question Re how fast to heat?
    FirstVallartaPool's Avatar
    Apr 2016
    Puerto Vallarta mexico
    109
    Was wondering as i still haven't figured out roughly how fast will our heater warm our pool if outside temp is 80?
    Heat siphon specs:
    Model SX3.25HP 208/230 60 . 80,000 btu
    Pool approximately 3800 gallons
    Thanks all!
    Pool 3800 gaĺlon glass tiled concrete approximately 10 years old/ Puerto Vallarta
    Hayward sand filter S166t.
    Pool Pump Silver10/1115 1hp
    Heat siphon Sx3.25hp
    Hard Municipal Water tf-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Re: Pool heater question Re how fast to heat?
    1 btu raises 1 lb of water 1 degree f in an hour.
    3800 8.34lbs = 31,692 lbs 80,000 = 0.4 hours or 24 minutes for 1 degree temp rise. Assuming 100% efficiency and no loss. So, maybe assume 30 minutes per degree f.
    Apr 2016
    109
    Excellent thanks! That's pretty fast as i plan on running filter for about 3 hours a day in December when heater is on....that should be perfect. Right now 2 hours is working fine to filter pool only per day. December temps are roughly 77f days and 19f nights.
