Thread: Leaking between tank body and seal plate
    Sep 2016
    weston
    2
    I have a sta-rite p2ra5f-125l pump. Its a dura-glas series pump.
    It has not been used for years and I've been rebuilding it. I started with a new motor which I successfullyn replaced with new shaft seal. Then I found a crack in the seal plate. I purchaed a new seal plate (PENC203-193P) and it came with a square shaped round o-ring. When I assembled the tank body (c76-47p) and seal plate togeter, I found the stainless steel metal clam no longer fits - the new o-ring make it so wide that I can't thread the nut through to tighten. It was really hard to place the o-ring because the tank body does not have a groove for the o-ring.
    Interestingly enough, the old assembly did not have an o-ring between the seal plate and tank body. If I put the o-ring outside between the seal plate/the tank body and tighten with the stainless steel clamp, I get a leak.
    Looking for advise
    Apr 2015
    tucson, arizona
    511
    Re: Leaking between tank body and seal plate
    Sta-Rite Dura-Glas and Max-E-Glas Parts - INYOPools.com
    . There is always a o-ring between seal plate and tank body
    Sep 2016
    weston
    2
    Quote Originally Posted by kadavis View Post
    Problem solved. The old o-ring was in the tank body and I just didn't see it.
