Thread: Should I adjust TA?
    Saturn94's Avatar
    Mar 2015
    Virginia
    513
    Should I adjust TA?
    Gradually over the season my TA has dropped from 70 to 50 due to dilution from rain (had to pump out excess water on several occasions this season; not unusual for here). As usual, pH has remained very stable, 7.4-7.5, the entire season without having to add any MA.
    Is there any reason I would need to adjust TA back up to 70? Or just leave it where it is?
    Thanks.
    Edit: if it matters, borate is at about 40ppm per today's test.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Re: Should I adjust TA?
    Leave it at 50 and do a happy dance. The only reason to raise TA is if your pH has wild spikes up or down. 50 is fine for lots of pools. 40 is often too low. Your pH will tell you if you need to adjust TA. If pH gets jumpy raise TA 10 with baking soda.
    Saturn94's Avatar
    Mar 2015
    Virginia
    513
    Quote Originally Posted by pooldv View Post
    Thanks. I was thinking TA is fine as long as pH is stable.
    That brings up another question I have about TA and testing frequency. It's normal for my pool's pH to stay stable at 7.4-7.5 all season without having to add acid. Even so, I test TA once a month to see where it is. If pH is stable, is there still a reason to test TA on any regular basis?
    Jun 2014
    15,895
    Yes, it's still good to test all items at some point, even if we do stretch the frequency out a bit. One reason is new fill water. Many of us have water that has an elevated alkalinity content, so it's natural that with evaporation over time, and constant refills to the pool, that TA could creep-up on us.
    Saturn94's Avatar
    Mar 2015
    Virginia
    513
    I figured I'd give an update......
    pH started dropping so I adjusted pH and TA back up to where they normally are (pH 7.5, TA 70). So apparently TA of 50 is a little low for my pool.
    Aug 2014
    Northern IL
    4,615
    Sounds good!
